Any pci-e cards that are a decent upgrade to an x800xl that don't require a new power supply? Have a Thermaltake 480w, 18a on 12v rail. The more I think of getting a 8800gts, the more it looks like a complete system overhaul, power supply included. Just trying to weigh my options.
Given the W's im assuming it doesnt have ne 6pin pci-e plugs.
As i keep saying, im pretty happy with my 1950xt, so a 1950pro would be good and im pretty sure it uses std plugs?
Also helps if we know what $ u wanna spend.
So, anything thats not too extreme should be fine with that psu.
You can get an nVidia 7600GT, 7900GS or the 7900GT all of which uses less power than the X800XL and should provide a significant increase in performance; even the 7600GT. The X1800GTO will also provide increased performance, but they are no longer sold.
I have 2 sata hard drives, 1 dvd-rw drive, 2 gigs of ram, 3500+, Asus A8V mobo. I can cut out one hard drive if necessary. Also have an X-Fi Platinum sound card. That's pretty much it. I don't overclock.
The power supply has no pci-e 6 pin power plug. The adapters from a 4 pin molex to the 6 pin is $2 at my local computer shop.
I had my heart set on a x1950xt for $250, then I noticed the 8800gts dropped to $399, and even $320 with a rebate from Dell. But with that, we're talking a new $120+ power supply too, no doubt. Which leads me to ask will I be limiting myself processor-wise, so then I need a C2D, so that means new ddr2 ram, new mobo, etc etc.
Maybe I'm putting too much thought into this, I'm getting confused. Basically I want a boost to my games that won't cost me over $300 if possible. If I need a new power supply, that cuts my options pretty bad.
and add one Hard Disk, one optical drive, video card and CPU, use high end motherboard,
calculate Watts and divide by 12 to get amps. Add 2-4 amps for safety.
Compare to your power supply 12v rails.
Combined should not exceed requirements.
Max power output on 12v rails: look at box, subtract 3.3v + 5v maximum output from total
wattage of PSU and divide by 12 to get maximum amps on 12v rail. Should be higher than
requirements. That's why we add 2-4 amps.
