I bought a barebones case that had an MSI mobo pre-installed. I saw it accepted Athlon 64 CPUs so I got one and a heatsink/fan that supported Athlon 64.
Problem is, during installation I see the CPU FAN header on the mobo is a 3-pin, but the cable coming off the heatsink/fan is similar but 4-pin. It is NOT a 4-pin molex.
What do I do now? I try searching for a 3-pin to 4-pin fan power converter cable, but everything I get back is a typical 3-pin power to a 4-pin molex.
