I'm a n00b looking for a simple solution to wiring a Netgear MR814 to two computers using no wireless connections. One desktop running XP Pro the other is a laptop with XP home. I just want to access files on the desktop from the laptop with no internet connection. What do I need to get this working?
Connect both computers with cat 5 cable. follow the setup instructions for the router and you should be networked.
If you have tried this then let us know what is/isnt working.
Also might run an ipconfig /all from a cmd box and post it here for us to see.
If I plug the Cat 5 cables from the computers to the router, will it automatically detect them? I'm not sure how to configure for a wired network, since the web access screen will not be used. :?
This router would not be connected to the internet. With that said, how to login to the router and to configure it for two computers sending data to one another?
You should still disable the Wireless or add WPA security, even though not used. Will keep the your system secure.
Won't need any security measures since it will not be online nor will it be broadcasting wireless. It will just be the router wired to the two computers.
Okay, it seemed to work after running the windows network wizard on both computers.
Can two users access the same file at the same time? Had some problems there.
Quote :
Also how can the wireless portion be turned off? I noticed that it was broadcasting when it was hooked up. :?
2 computers can access files at the same time only if its read only. You can't have 2 people editing the file at the same time, with out a server controlling access.
Most wireless routers have a flag that allow you to turn off the wireless. Will have to login in a turn the radio/wireless off.
