Device Mgr. mistakes wireless card for PCI device
Archived from groups: microsoft.public.win2000.general (More info?)
I have an HP Laptop that will not recognize a wireless adapter. When I try
to install a wireless device (have tried several) the device manager
identifies it as a PCI device instead of a network adapter as it should.
Having recognized it as a PCI it will not recognize the correct drivers to
finish installation. I have tried the cards on my xp laptop and all have
worked.
One of the cards that I am trying to install worked previously on this
machine. Client complained that it stopped working. I wrestled with it for
a while and then wiped and recovered with fresh and updated install of
Win2Kpro. I did this to eliminate any possibilities of malware that might be
causing me the grief.
Any thoughts? Please!
8 answers Last reply
More about device mistakes wireless card device
  1. Archived from groups: microsoft.public.win2000.general (More info?)
    Check with the manufacturer of this device for a digitally signed Windows
    2000 specific device driver for the device. Run the Update Driver wizard
    using the Update Driver button, but do not let Windows 2000 automatically
    detect devices. Instead, click Have Disk when prompted, and manually point
    the wizard to the appropriate driver.
    Regards,
    Dave Patrick ....Please no email replies - reply in newsgroup.
    Microsoft Certified Professional
    Microsoft MVP [Windows]
    http://www.microsoft.com/protect
    | worked.
    for
    be
  2. Archived from groups: microsoft.public.win2000.general (More info?)
    Dave, you are somewhat missing the pint of my problem. I have tried
    installing drivers a dozen times over using every different method I can
    imagine; different versions of drivers, different cards from another
    manufacturer. I have also been on the phone with SMC technical support for
    two different versions of their cards with no resolution. I have tried known
    working d-link cards as well.
    What is happening here, for sake of comparison; when I install a new card
    into my xp laptop, the device manager sees it as a network adapter and allows
    the installation of drivers. When I install any of the same cards to the
    Win2K laptop, the device manager sees the new card as a PCI device and
    henceforth will not allow the installation of drivers. My question to the
    forum is, is this normal behavior for Win2K to see a 802.11b card as a PCI
    device? Even if it is recognized incorrectly would this hinder the
    installation of drivers?
    Another question for you Dave. This laptop's OS is installed allong with
    many proprietory applications using a ghost image. (The laptop is used for
    diagnosing malfunctions on heavy equip) Can I do an upgrade to WinXP without
    wiping the applications on the pc? I know they (the apps) will work with xp
    but have never tried an upgrade from one OS to the other.
    > Regards,
    > | worked.
    > for
    > be
  3. Archived from groups: microsoft.public.win2000.general (More info?)
    for
    known
    * The pint I'm missing is; you've told us nothing more than "it will not
    recognize the correct drivers"
    allows
    the
    * Yes it is normal. In this case normally you can right click on the 'bang'
    device and choose 'Update Driver', then at some point choose 'Have Disk'
    for
    without
    xp
    * Yes, it works. Start the upgrade process from Windows 2000. Be sure to
    have on hand the normal backups of any data. For all applications installed
    check the application developers web site for instructions or release notes
    on upgrading the operating system.
    Regards,
  4. Archived from groups: microsoft.public.win2000.general (More info?)
    Dave, thanks for your patience with me!
    I do not know what more you would need here, but I will elaborate as best I
    can.
    I have the originall drivers for these devices on cd and have also
    downloaded updated drivers for these devices from the manufacturer's website.
    I have attempted to install the drivers by using the "have disk" function
    and pointing to extracted driver folders or the appropriate folder on the cd.
    In all cases that I have tried I recieve the error that windows cannot find
    a driver for the device and it will not function. As I said before I have
    gone throught this with the techs at SMC with no resolution. They seem to
    believe that the OS is recognizing the card incorrectly as a PCI device and
    that is my problem. I am asking now for your opinion if you agree with them?
    Do I have a hardware issue? It cannot be the cards as they work on my xp
    mache. Or is this normal for
    Win2k to recognize such a card as a PCI device instead of a network adapter?
    > for
    > known
    > allows
    > the
    > for
    > without
    > xp
    > Regards,
  5. Archived from groups: microsoft.public.win2000.general (More info?)
    If you believe the device is not connected to the pci bus then the system
    bios may need to be upgraded. Check with the laptop manufacturer on this.
    Regards,
    I
    | can.
    website.
    cd.
    find
    and
    them?
    adapter?
  6. Archived from groups: microsoft.public.win2000.general (More info?)
    Dang, have flashed bios.
    New problem!!!
    Tried another card and system recognized it as an adapter (Yahoo!) Driver
    loaded but now have new problem. Device will not start because it cannot
    find enough free resources (error code 12). Searched Microsoft and found
    they recommend that OS might be a problem or bios. I think I will now try to
    move this OS to winxp and see if I can resolve this. BTW, I disabled as many
    unused devices as I could, including the onboard nic to gain resources, no
    resolution. If you can spare me one more response regarding this error
    before I upgrade OS I would apprieciate it.
    > Regards,
    > I
    > | can.
    > website.
    > cd.
    > find
    > and
    > them?
    > adapter?
  7. Archived from groups: microsoft.public.win2000.general (More info?)
    This one may also help.
    http://support.microsoft.com/?id=244601
    The laptop may be non-ACPI system. If this is the case Windows XP won't help
    the situation.
    http://support.microsoft.com/?id=252420
    For the code 12;
    In the same properties page where the error message occurs, click the
    Resources tab. Windows 2000 attempts to flag the associated device that is
    in conflict with the device in question. You should avoid manually assigning
    resources in a Plug and Play system, because this can create potential
    problems in the future as Plug and Play attempts to do its job at a later
    time. Either disable or remove the device that is in conflict to see if the
    device reporting the error message starts. You can then add the device you
    removed back into the system and see if the device can take new resources on
    its own. The following information describes how this may occur:
    Plug and Play attempts to automatically assign resources to devices. It
    examines a "form" that defines the resources that a device can use and draws
    its choices from that list. In that same form (actually a structure in the
    configuration memory space of the device) is a list of resources that the
    device prefers to use. When two devices contain identical "preferred"
    settings, something commonly referred to as "resource affinity" occurs.
    Devices fight for possession of a specific resource, which causes a
    deadlock. A similar situation is created by resource dependency
    configurations. In that same form mentioned earlier, devices may define
    resource dependencies. For example, "If this device is assigned x IRQ, then
    use y I/O port address." The dependent resource may be in conflict with
    another device causing a failure. Disabling the working (but conflicting)
    device changes the order of enumeration and may force the other device to
    take on new settings that are not in conflict. This behavior occurs more
    often in Windows 95/98 where device enumeration occurs in a specific order,
    whereas Windows 2000 multithreads enumeration enumerates all device at once.
    Although multithreading helps to alleviate this problem, it may not resolve
    the problem. If the procedures outlined here do not resolve the problem,
    check for updated device drivers from the manufacturer before attempting to
    manually assign resources to the device.
    Sometimes Windows 2000 cannot detect which device is actually in conflict.
    This behavior can occur because errors in the IRQ routing tables or I/O port
    conflicts are created by an improperly configured PCI-to-ISA bridge.
    Complete coverage of each of these concepts is outside the scope of this
    article. The most common method for resolving this problem is to update the
    system BIOS. On non-ACPI systems, you may be able to select an alternate IRQ
    routing table source. Refer to the Microsoft Knowledge Base for articles
    explaining IRQ routing in Windows 2000 and how to edit the registry to
    select an alternate method. Because the most common resolution in any system
    BIOS update is to resolve error messages in IRQ routing, you should resolve
    this problem by checking with the manufacturer of the device for an updated
    system BIOS.
    This behavior may also occur because of irresolvable conflicts in an ISA/PCI
    mixed environment. The ISA bus is not designed with Plug and Play in mind.
    Because of this, the PCI bus has no reliable way of detecting the resource
    settings of ISA devices. Try removing any unneeded ISA devices in the system
    to see if the device in question properly configures itself. If this works,
    check the System Information tool for free resources and set the ISA device
    for the appropriate configuration. In the case of a Plug and Play ISA
    device, try replacing the device in an alternate ISA slot. If this does not
    resolve the issue, check with the manufacturer for a digitally signed
    Windows 2000 device driver for the ISA device. You can also try starting
    into the system BIOS and setting the resources for the ISA device as
    Reserved by (or for) ISA. This action may manually remove the use of the
    resource in question from the Plug and Play equation. If none of these
    recommendations resolves the problem, you may have to find a PCI version of
    the ISA device.
    Regards,
    | New problem!!!
    to
    many
  8. Archived from groups: microsoft.public.win2000.general (More info?)
    Howie-
    I'm sure by now you've wiped the machine, but in case you haven't here's my
    two cents.
    I recently got the same error code as you are getting and after disabling
    devices, changing whether BIOS or plug and play assigns IRQ's, and asking
    myself "why does the KB article say to change the IRQ in device manager for
    the device getting the error when the resource tab of the device reads 'not
    using any resources, driver has not been loaded' and so there's nothing to
    change?" I realized it was caused by an incorrect driver. I'm not saying you
    used the wrong driver (though that's what I "might" have done), but maybe
    just try an older version? (I know you said in an earlier post you'd tried
    many versions but I didn't know if that applied to this new device).
    And just for the record Dave, there was no need to get defensive in your
    second post. If you re-read Howie's first post you will I'm sure agree that
    you did miss the point because Howie said his problem was that Windows was
    incorrectly identifying his device - he only mentioned the drivers not
    installing as a "proof of concept" to show that Windows really didn't see the
    correct hardware. For example if Windows saw your network card as a monitor
    then you could have network drivers that were logo'd and Windows would still
    say the location didn't contain any drivers for your device.
    Nick Staff
    > New problem!!!
    > > Regards,
    > > I
    > > | can.
    > > website.
    > > cd.
    > > find
    > > and
    > > them?
    > > adapter?
Wireless PCI Devices Windows
