Can't migrate system to new machine
Archived from groups: microsoft.public.win2000.general (More info?)
I posted this elsewhere, but this group is way more active...
I started out with a used 233 MHz machine with a 3-gig HD running win2K. I
only want to use this machine for applications that won't run under linux
(turbotax, scanner, camera, etc.). The previous installation seemed OK after
I deleted Jason's pre-school games (all that the machine contained) and
installed what I needed including whatever upgrades MS said I needed. Added a
5-gig drive as E:\ and added more needed software. Everything ran fine,
except for the fact that I only have 650 meg unused space on the c:\ drive and
some software insists on adding itself to the c:\drive.
This machine has always taken a long time to boot, sticking several minutes
each in the 'applying security policies' and 'applying personal settings'
screens both before and after installing the MS security updates from the
April 2004 CD. Deleted everything I could think of, but no change.
Acquired a faster machine. Put the C:\ drive in and got nothing but the blue
STOP <etc> screen. Tried all possible varieties of repair from my win2K CD,
all of which claimed success. Still got the blue STOP screen.
Used hdclone to move C:\ to a new 20-gig drive. Same STOP screen. Tried
original 3-gig drive in several different machines. Same STOP screen.
Installed brand-new win2K system on freshly formatted 20-gig drive in faster
machine. Works OK, except machine isn't THAT much faster because the BIOS
only allows it to run at 100MHz instead of the 850MHz it's supposed to be.
Put 20-gig drive in original 233 machine. Blue STOP screen.
Based on experience here, it would seem that there's some rule about win2K
running only on the machine it was created in. Could this possibly be true?
I still need to install software and I have no idea how much space on C: it
will require, and 650 meg seems like not anywhere near enough squish room
anyway.
Help!
Cheers, Bev
"Yahoo has released its own search engine. For more info,
type 'yahoo search engine' into Google." -D.Miller
5 answers Last reply
More about migrate system machine
  1. Archived from groups: microsoft.public.win2000.general (More info?)
    http://support.microsoft.com/default.aspx?kbid=292175
    http://support.microsoft.com/default.aspx?scid=kb;en-us;824125
    You will have to repair the win2k installation.
    You cannot move a win2k/winxp installation to another sys, without repairing
    the installation.
    "The Real Bev" <bashley@myrealbox.com> wrote in message
    news:42596BF5.92649505@myrealbox.com...
    I
    after
    Added a
    and
    minutes
    blue
    CD,
    faster
    true?
    it
    > anyway.
    > Help!
    > Cheers, Bev
  2. Archived from groups: microsoft.public.win2000.general (More info?)
    Those were not precisely applicable :-(
    > the installation.
    Yes. I repaired the system several times using the win2K cdrom. Each time
    the resulting "repaired" system refused to boot. I was only able to run a
    given hd with a running win2K installation in the machine in which I created
    the installation. Are you telling me that it is NOT possible to move a
    running win2K HD to a different machine?
    > I
    > after
    > Added a
    > and
    > minutes
    > blue
    > CD,
    > faster
    > true?
    > it
    > > anyway.
    > > Help!
    Cheers, Bev
  3. Archived from groups: microsoft.public.win2000.general (More info?)
    If I'm reading your initial post correctly, the second link is applicable.
    Since the hardware/mobo of the new sys is different than the origonal sys,
    on which win2k was installed.
    You cannot, in nearly every case install win2k on a sys, then either move
    the installation hd to another sys, or for that matter change the mobo,
    without performing the repair of the win2k installation.
    (In order for a move not to require a repair, both origonal hardware and new
    would have to be identical)
    This applies to winxp also.
    If having performed the repair install your sys still will not boot, then it
    is likely some form of hardware conflict.
    You could try with a bare sys, ie Keyb, mouse,single mem.stick,single hd,
    monitor,no cards/other devices.
    news:4259C253.B9AB8792@myrealbox.com...
    repairing
    > > the installation.
    time
    created
    win2K.
    > > I
    linux
    OK
    > > after
    and
    > > Added a
    fine,
    drive
    > > and
    > > minutes
    settings'
    the
    the
    > > blue
    win2K
    > > CD,
    Tried
    > > faster
    BIOS
    be.
    win2K
    > > true?
    C:
    > > it
    room
    > > > anyway.
    > > > Help!
    > Cheers, Bev
  4. Archived from groups: microsoft.public.win2000.general (More info?)
    Yes, upon re-reading it I see that you're right. Thanks, and sorry for
    doubting you.
    Someone else suggested removing all the devices with the device manager,
    shutting down, making the switch, and letting it find all the new hardware.
    Is that functionally the same? I find either/both ideas terrifying :-(
    The machine is back running the way it was, with a third HD added (containing
    the new win2K system, but with lots of space left over), and I am reluctant to
    try fixing it if it ain't broken. I will, however, save this information for
    when it becomes essential to do deal with it.
    I did several repair-with-win2k-cdrom procedures, but without the
    apparently-essential machine-swap in the middle.
    > repairing
    > > > the installation.
    > time
    > created
    > win2K.
    > > > I
    > linux
    > OK
    > > > after
    > and
    > > > Added a
    > fine,
    > drive
    > > > and
    > > > minutes
    > settings'
    > the
    > the
    > > > blue
    > win2K
    > > > CD,
    > Tried
    > > > faster
    > BIOS
    > be.
    > win2K
    > > > true?
    > C:
    > > > it
    > room
    > > > > anyway.
    > > > > Help!
    Cheers, Bev
    ooooooooooooooooooooooooooooooooooooooooooooooooooooo
    "With sufficient thrust, pigs fly just fine. However,
    this is not necessarily a good idea...."
  5. Archived from groups: microsoft.public.win2000.general (More info?)
    I have moved an o/s many times, and/or significantly amended hardware. I've
    never had a problem with a repair install.
    Though if ammending hardware I prefer to take it one change at a time.
    news:425B2F70.BE4B3AE6@myrealbox.com...
    applicable.
    > doubting you.
    sys,
    hardware.
    (containing
    reluctant to
    for
    move
    new
    then it
    hd,
    > > repairing
    > > > > the installation.
    > > time
    run a
    > > created
    a
    > > win2K.
    > > > > I
    under
    > > linux
    seemed
    > > OK
    > > > > after
    contained)
    > > and
    needed.
    > > > > Added a
    > > fine,
    c:\
    > > drive
    > > > > and
    several
    > > > > minutes
    > > settings'
    from
    > > the
    change.
    but
    > > the
    > > > > blue
    > > win2K
    > > > > CD,
    > > Tried
    screen.
    in
    > > > > faster
    the
    > > BIOS
    supposed to
    > > be.
    about
    > > win2K
    possibly be
    > > > > true?
    on
    > > C:
    > > > > it
    squish
    > > room
    > > > > > anyway.
    > > > > > Help!
    > Cheers, Bev
Windows
