Need help picking parts......
robojon
13
Hi all....
I’m a novice when it come to building a comp so I need help picking parts......
Id like to not go over $1000.....
Ill be using it for Graphics & Video Editing & random stuff.... mabe OCing
Not sure where to start.....
Should I go Pentium D or C2D or something AMD?
Not sure how to pick a MOBO.....
I want 2 GB RAM...
Video card... thinking 7600gt
Lost when it comes to PSUs... (Like how much watts and all that)
So if people want to help that would be cool!
Assman
2,274
definitely go with c2d(e6300 or e6400), it is the best $/performance cpu today, it will put any p4 or pD to shame.
mobo, since you're on a budget and not planning on extreme gaming no point of going sli or crossfire, something like ASUS P5B-E or regular P5B or GIGABYTE GA-965P-S3 will do fine.
ram, i'd go with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400), great ram, stable, ocable. i've never had problems with it.
as for video, 7600gt is ok for your setup. a 550w or even 500w should give enough juice.
SpudTECH
121
Don't go cheap on your motherboard OR powersupply. About 85% of problems can be avoided if you do.
The rest of it can be on the cheaper side, but you will avoid most problems and leave yourself room later to upgrade if you spend what it takes to get a good namebrand powersupply (about 500-650watts should do.) AND a good motherboard. Make sure the motherboard is either LGA775 for Intel or AM2 for amd.
also see if you can increase your limit by at least $175 so you can get the parts that will keep you from lots of heartache.
NotAPimecone
299
If you don't plan to take your FSB past 400 MHz, either one should do just fine, as you would only be running them at their specified speed. I don't really know which one is better than the other beyond that, but 400 FSB is a pretty good overclock (about a 50% increase over stock speed, assuming you don't lower the multiplier - depending on the board, this may not even be possible anyway), one for which you'd probably want something better than the stock cooler (though some people have made do with the stock cooler at such speeds, see WiZ83's budget Core2 thread).
robojon
13
ok cool thanx.....
ok umm..... heres what i have so far......
case: $64 COOLER MASTER Ammo
http://www.newegg.com/Product/Product.asp?item=N82E16811119098
mobo: $150 ASUS P5B-E
http://www.newegg.com/Product/Product.asp?item=N82E16813131070
CPU: $183 C2D E6300
http://www.newegg.com/Product/Product.asp?item=N82E16819115005
RAM: $209 G.SKILL 2GB (2 x 1GB)
http://www.newegg.com/Product/Product.asp?item=N82E16820231098
VC: $119 eVGA 7600gt
http://www.newegg.com/Product/Product.asp?item=N82E16814130017
PSU: $96 OCZ GameXStream
http://www.newegg.com/Product/Product.asp?item=N82E16817341001
HD: $95 Seagate 7200.10 320GB
http://www.newegg.com/Product/Product.asp?item=N82E16822148140
Optical drive: $30 NEC 18X DVD+R/48X CD-R
http://www.newegg.com/Product/Product.asp?item=N82E16827152076
OS: $140 XP Pro SP2b/Upgrade Coupon for Vista
http://www.newegg.com/Product/Product.asp?item=N82E16832116175
(Arctic Silver 5 Thermal Compound $6) do i need this?
Total: $1,135
Thoughts Please!!!
skyguy
2,408
Looks good. Dunno about the mobo.....I heard that the P5B's were a bit finnicky about RAM. I can't confirm since I don't own one.
Other than that, good specs for the price!
robojon
13
Thanx ill switch to the Gigabyte board...
is there any other comment... recommendations
Do I need Thermal Compound?
Is there any thing ive left out?
Assman
2,274
if you're going to use stock cooler you don't need thermal compund.
p5b is an ok board, don't know about g.skill but with corsair it's a good ocing combo. Also, if you want to raid sometime in the future, do not get p5b, raid driver is a pain in the ass.
as i said before GIGABYTE GA-965P-S3 is a solid mobo, good luck
NotAPimecone
299
Thermal compound is not necessary, as the stock heatsink comes with some thermal compound pre-applied, but it's nice to have around. If you ever need to remove your heatsink (like if you didn't get it on right in the first place), you'll need to clean the thermal goop that's already on there off and replace it with something like AS5.
Assman
2,274
Save as much as u can
and wait as long as you can (dx 10 card i mean)
nvidia should release mid-range cards next year (hopefully by summer :) )
When it comes to vga i have no patients, from my sig you can see that my video card is s**t, so when i get 8800gts it should be quite a jump for me.
