Archived from groups: alt.games.neopets (
More info?)
bodcat1 wrote:
> You know, I have a vacuum sealer. I can seal things pretty much back to
> "original" with it. I do it with marshmallow bags all the time to keep them
> from going hard.
> Makes me wonder if someone might be doing that?
Superglue can also "seal" the packs if they were opened carefully
enough...I've run across that once or twice with the giveaway
being that the packs opened along the crimps a bit too easily.
> "Gareeth" <Gareethnews@hotmail.com> wrote in message
> news:b_yKe.174049$9A2.116628@edtnps89...
>>viciousrecycle@adelphia.net wrote:
>>>So tonight I bought 8 packs of *sealed * original Neopets TCG cards
>>>(because thay were on sale) and when I got home to input my codes it
>>>said every _single_ one had already been used WHAT!!!!???? I miffed as
>>>that is the main reason I bought the cards. Anyone else had this
>>>issue/problem? Is it some weird glitch?
>>I think some corrupt types figured out ways to generate that codes. It
>>seemed to happen to a lot of people with both the TCG cards and the
>>Mcdonald's toys. I would try to make TNT aware of your problem and show
>>proof that you purchased the cards but bases on other people's experiences
>>I wouldn't hold out a lot of hope.
>>Gareeth
Where did you buy the cards?
Neopets! It's FREE! Create and care for a virtual pet, explore,
play games and more!
http://www.neopets.com/refer.phtml?username=dreamstalkerwolf
