Archived from groups: microsoft.public.pocketpc (More info?)
Hi,
I have an app that logs information from a serial port on my Pocket PC.
It appears that when I turn the PocketPC off, the app stops recieving data.
How can I force the application to keep running ALL THE TIME.
"Brian" <nospam@nospam.com> wrote in message
news:%23niYxE2LFHA.2748@TK2MSFTNGP09.phx.gbl...
> Hi,
data.
> Thanks
> B >
You need to be more clear.
Is the PPC RECEIVING serial data from an external
device or is it TRANSMITTING serial data from some
app running on it?
Either way, if you turn the PPC off, things will stop, as expected,
no surprise there.
Short answer, to either config., don't turn the PPC off.
"Brian" <nospam@nospam.com> skrev i en meddelelse
> Hi,
> data.
> Thanks
> B >
> Hi,
> data.
> Thanks
Is there a reason you are turning off the PPC? If only for the screen, etc,
then there are utilities to turn off the screen, as others have stated. Be
sure to adjust your power setting to not automatically turn off as well.
But the real question would have to be "Why are you turning it off"? After
all, in a power down mode the ports will be off, despite a heartbeat, so to
say.
Thank Guys,
Yes, I need the screen to power off so the utilities mentioned will help.
And yes I have set all the power options.
Thanks Again.
B
"xTenn" <xTennREmoveThisPart@tds.net> wrote in message
news:%230l59J8LFHA.3076@TK2MSFTNGP14.phx.gbl...
>> Hi,
>> data.
>> Thanks
> etc, then there are utilities to turn off the screen, as others have
> stated. Be sure to adjust your power setting to not automatically turn
> off as well. But the real question would have to be "Why are you turning
> it off"? After all, in a power down mode the ports will be off, despite
> a heartbeat, so to say.
