i'm new at this and not sure if i did the right thing, and i definitely need your advices and suggestions...
this is my setup:
gigabyte ga-965p-ds4 bios version: F6
intel pentium d 926 3.0mhz dual core
kingmax(Nanya technology) ddr2 pc667 512mb x 2
seagate 80gb and samsung 250gb hard disks
gigabyte g-power pro cooler (air)
So far got my timings at 3-3-3-9
memory frequency is 480MHz
Bus speed 240MHz
FSBRAM 1:1
multiplier is 15x
rated FSB 960MHz
core speed is 3600MHz
its pretty stable with memtest and prime95, but i don't know if this is right, first am i suppose to have a 480MHz for my pc667 RAM? is it better or need i try to change it?
increased the Ram voltage to 2.10volts and processor voltage to 1.38volts from 1.28volts
holding temperature is 50C
dont really need a high oc, just high enough not to overheat... runs 57C to 62C with prime95
this is my setup:
Bus speed 240MHz
FSBRAM 1:1
multiplier is 15x
rated FSB 960MHz
