Primary Drive Space Problem
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I have a space problem in my primary drive. One file, pagefile.sys, contains
1.12 GB and seems to grow each day. I have not been able to open it to view
its content.
My question is: Is it possible to reduce/limit/ the size of this system
file. And if so, how might I accomplish this? ....Thanks...CinciDave
> its content.
Apparently you have about 768 MB of RAM installed. Windows, using the
default settings, will set the pagefile to 1.5 x that amount, roughly 1.12
GB. This file is part of the virtual memory mechanisms - no need to open it
and view the content.
You could use System Properties> Advanced> Performance> Settings> Virtual
Memory to change from Windows-managed to Custom and limit the pagefile size
BUT that it is growing now indicates that you recently performed some task
that needed a large pagefile. The auto-manage settings are simply doing
their job. The file should shrink to 1.2 GB in a day or two if that extra
allotment is not needed again.
To learn more about virtual memory in WinXP, see this article:
http://www.aumha.org/win5/a/xpvm.htm
Sharon F
MS-MVP ~ Windows Shell/User
I suggest that you leave pagefile.sys alone and consider archiving seldom
used files, especially picture and music files. The system needs around 15%
of the system drive to be available for temp files and free space for disk
defragging, so it sounds like some sort of hardware upgrade is in order.
Colin Barnhorst [MVP Windows - Virtual Machine]
"CinciDave" <CinciDave@discussions.microsoft.com> wrote in message
news:74B891B1-473D-423E-B016-0552065DDD42@microsoft.com...
>contains
> view
> its content.
I followup by suggesting that you install a second, fast HD, with a 2.1 GB
primary partition at its head and assign the page file to it exclusively, in
the manner Sharon F has posted. This will free space on C: and increase
system performance.
Jack E. Martinelli 2002-05 MS MVP for Shell/User / DTS
Help us help you: http://www.dts-L.org/goodpost.htm
http://www.microsoft.com/athome/security/protect/defaul...
Your cooperation is very appreciated.
"Sharon F" <sharonfDEL@ETEmvps.org> wrote in message
news:elaJdyk$EHA.3908@TK2MSFTNGP12.phx.gbl...
contains
view
> > its content.
it
size
> Sharon F
> system performance.
Thanks, Jack. I was so worried about his pagefile that I forgot about his
problem with space on his primary drive.
Sharon F
Ask the community
