The only part I've got left to buy for my new PC is a power supply and I'm wondering which to get.
Core 2 Duo E6400 2.13ghz
ATI X1950XT
2GB DDR 800mhz
1 SATA HD
1 IDE DVD-RW
http://www.extreme.outervision.com/PSUEngine suggested a 425W PSU (as I plan on trying to overclock the CPU), so 500W should be ok.
Here are some I've found.
OCZ GameXStream 600W PSU - 120mm Fan SLI Ready ATX12v v2.2 - £82
Coolermaster IGreen 600W PSU - 85% Efficiency 8pin ATX12V v2.2 120mm Fan - £87
Seasonic S12 Series 600W SLI Certified ATX2.0 PSU - £90
Tagan Dual Engine TG600-25 600W PSU
- £91
Thanks
EDIT - Seems I entered some info into the PSU calculator incorectly, it suggested a 425W PSU this time.
ATI X1950XT
2GB DDR 800mhz
1 SATA HD
1 IDE DVD-RW
- £91
Thanks
