I am installing a mobo. THe case came with brass fittings but it also has these 'bumbs' that have a screw hole in them.
I have an image, it is small but you can see if you look close:
WHen i set the mobo on the 'bumbs' the mobo lines up prefectly with the i/o plat as well as the bumps line up perfectly with the mobo screw holes. Can I just go ahead and not use the brass fittings?
Here is the mobo:
GigatByte GA-965G-ds
Here is the case:
Ultra Wizard
Here is the mobo:
Here is the case:
Ultra Wizard
