it says it does support it link:
http://www.msi.com.tw/program/products/server/svr/pro_svr_detail.php?UID=484
[code:1:e5803ea745]
Chipset
• VIA® K8T800™ Chipset
- Supports AMD Opteron™ processors
- 800MHz HyperTransport FSB
- Support for AGP 2X/4X/8X/Pro
- Ultra V-Link 1.06GB/s high bandwidth North/South Bridge interconnect
• VIA® VT8237™ Chipset
- A 33MHz/32bit PCI 2.2 compliant bus interface supports up to 6 external devices.
- Dual Channel Serial ATA/RAID (0, 1)
- Dual Channel ATA 33/66/100/133
- USB 2.0, 6 ports, UHCI compliant
- Advanced power management capabilities
- including ACPI/OnNow
- LPC bus to connect peripherals such as super I/O and BIOS.
- IO APIC controller.
Main Memory
• 144-bit DDR at 200, 266, 333, 400MHz.
• Supports interleaving memory within DIMMs.
• ChipKill ECC allows continuous correction of 4-bit errors in a failed x 4 memory device.
• Requires 184-pin Registered ECC DDR DIMMs (maximum 4)
[/code:1:e5803ea745]
ionno i can't tell rofl rofl
