Archived from groups: microsoft.public.windowsxp.basics (More info?)
I'm trying to create a subdirectory on my hard drive (for Quickbooks
accounts) and am instructed to:
"From the DOS prompt C Type CD QBOOKSW"
When I open my Command prompt...the first line is:
CDocuments and settings/Debby/
At the prompt type "cd .." then do it again until the prompt is "C:\". Then
you are ready to continue. Notice that there is a space after the "cd" and
then two dots.
Colin Barnhorst [MVP Windows - Virtual Machine]
"dlb" <dlb@discussions.microsoft.com> wrote in message
news:3C840422-CA50-40BE-9660-DCCA60137C54@microsoft.com...
> "From the DOS prompt C > Type CD QBOOKSW"
> Help.
> dlb
The command CD \QBOOKSW then press the enter key will work. The command
prompt will look like - C:\QBOOKSW>.
It will take you to the root of the default drive (C and then take you to
the QBOOKSW directory off the root directory of C:
You could also break down the command into multiple lines.
CD \ then press the enter will give you a command prompt of C:\>
CD QBOOKSW t hen press the enter will give you a command prompt of
C:\QBOOKSW>
For any DOS command you can always type the command then a space and /? and
then press enter to get help for the command.
> Help.
> dlb
The command to make a directory in MS DOS is MD ("Make Directory" )
CD is for "Change Directory".
While at root directory type below, if not type at root directory, type
"CD.." then press [enter] ).
Then the syntax is:
C:\> MD QBOOKSW [enter]
then C:\> CD QBOOKSW will take you to
C:\QBOOKSW>
The OP asked how to create a subdirectory not how to change to a
subdirectory.
"LVTravel" <trash@dd.com> wrote in message
news:10v2mlb1jtk3gfe@corp.supernews.com...
> to
> C:\QBOOKSW>
> and
>> "From the DOS prompt C >> Type CD QBOOKSW"
>> Help.
>> dlb
