Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Finalizing build, help
MB: Asus P5B Deluxe P965 $185.99
Proc: Intel® Core 2 Duo E6400 Conroe Processor 2.13GHz, 1066FSB, LGA775, 2MB Cache Retail $223.90
Ram: Corsair TWIN2X2048-6400C4 2GB Kit DDR2-800 XMS2-6400 Xtreme Performance Memory Retail $272.80
HD: Western Digital Caviar SE16 WD3200KS 320GB Serial ATA II 7200RPM Hard Drive w/16MB Buffer $95.50
DVD: Plextor PX-750A-BP/BL 16X Internal Dual Layer DVD±R/RW (Black) $62.99
PS: Kingwin Maximum Power ABT-520MM 520W Power Supply w/2 Blue LED Fans Retail $71.99
Case: Coolermaster RC-532-SKN1 Centurion 532 Mid Tower Case Retail $79.99
Vid: Asus EN7300GT SILENT/HTD/256M GeForce 7300 GT PCI Express 256MB DDR2 Video Card w/DVI Retail $99.99
Etc: Zalman CNPS9700 LED Ultra Quiet CPU Cooler w/Super Thermal Grease ZM-STG1, Fan Speed Controller FAN MATE 2 Retail $64.99
Estimated Subtotal $1158.14
I put this build together on zipzoomfly (newegg charges tax here). Looking for a decent gaming rig, also will be doing quite a bit of XNA work, so programming/3d modelling is another requirement.
Skimped on the video card because I'll upgrade when the DX10 cards get cheaper.
Not sure if that's the motherboard I should go with.
Looking for suggestions that will keep me under $1200. Thanks.
Sponsored Links
If you're not needing SLI or some of the extra goodies on the Asus board, take a look at the Gigabyte S3 or DS3. Saves you $50-60.
Also check out the Seagate 7200.10 drives. About the same price as the WDs, but have faster access times with the perpendicular recording.
The eVGA 7600GT is only $16 more after the $20 rebate at zipzoom.
You'll get a dozen opinions on memory. Corsair is good stuff, but you pay for the name. There's other quality brands out there typically for less. OCZ, G. Skill Geil, etc.
Reply to AMDThunder
There are 1275 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
