Tom's Hardware > Forum > Overclocking > AMD > Overclocking 4800 x2 on gigabyte galaxy 2 3d water cooling
Forum Overclocking : AMD - Overclocking 4800 x2 on gigabyte galaxy 2 3d water cooling
I just got my new x2 4800+ with a 2 mb cache and I have it running at 2.9ghz at stock voltages ht multiplier is 4, My crappy mobo doesnt have an option for a memory divider so I dropped my ram down to 667 and tightened the timings. With 2 instances of prime95 running my temps are maxing out at ~37 degrees celcius. Am I forgetting something? In the meantime Ill see if I can hit 3ghz.
Sponsored Links
When I try to go past 2.9 Windows gets stuck on either the first loading screen or the 2nd screen when I log into my account. Anyone know how to fix this
Reply to ThatGuy5256
maybe you should try upping the voltage
Reply to JCushing
There are 799 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
