Yes No
Ads
Tom's Hardware > Forum > Networking > Routers & Gateways > Netgear MR814 problems, need help
Forum Networking : Routers & Gateways Netgear MR814 problems, need help
I have Comcast high-speed Internet, connecting to a Netgear MR814 v2 wireles router. The router is set as a DHCP server, with a MTU of 1500 bytes and 64-bit encryption and MAC filtering on the wireless connection. The past month or so, I've been having big problems with my Internet connection. The connection intermittently drops, and it often takes 4 or 5 attempts for a page to load. I'll often get Server Not Found. This is sort of cyclical, sometimes things will load on the first attempt, but it still takes 30+ seconds. What's more bizarre is that this also happens when I connect through the router with a cable (disabling the wireless adapter on my machine). When I connect directly to the cable modem, there are no speed issues, so this does not appear to be an issue with Comcast.
I'm usually running one or two machines on the network, either two with WinXP Pro, or one WinXP and one OS X. There are no bittorrent or similar services running, it's basic web browsing, sometimes AIM, and occasionally my VPN for work. Even with no VPN or AIM running, the problems are the same. The router has the latest firmware, and there is no port forwarding or filtering.
The slow connection happens on any computer connected to the network, so I don't think it's spyware or anything like that. Something has to be up with the router, I think. Does anyone have any suggestions?
Reply to jmb1115
I have a netgear FVS338 with comcast cable. I had to lower the MTU to 1420 in order to get some sites to load properly.
Also check with Netgear forums, a source for good info/help.
Then the Speed utilitys under tools at DSL Reports will help you diag your connection issues.
My Comcast connection requires the MAC address of the PC used to setup the services. Make sure you have cloned this in.
Reply to blue68f100
There are 1880 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
My desktops internet. HELP
By Realbeast, 1 day ago:
Sure could be a virus or malware, you should use a good free antivirus and...
Best offers
Top experts
