Tom's Hardware > Forum > CPU & Components > Other Components > Cooling setup/PCI slot case fans
Forum CPU & Components : Other Components - Cooling setup/PCI slot case fans
I am putting together a new system and I'm trying to decide how many fans I need to put in and how powerful they need to be. Here's the setup:
Core 2 Duo 2.4 Ghz
2Gb 667 DDR2 RAM
120 Gb 5400 rpm HD
512mb nVidia 7600gs(with fan)
500w power supply(with fan)
2 CD/DVD drives
The case I currently have has one side 80mm fan for intake and one rear 120mm fan for exhaust. I don't plan on overclocking it anytime soon, so I was wondering if this would be sufficient.
Also, how worthwhile are PCI slot fans?
Thanks
Sponsored Links
This really isn't enough to go on, but I would say it should be OK.
Reply to sruane
What more information would be needed?
Reply to Izzardius
- 0 +
What case are you using? What is room temperature? How are your cables routed?
Reply to sruane
Standard ATX case, room temp is about 70 or so, possibly hotter during the summer, nothing special for the cables.
Reply to Izzardius
- 0 +
Quote :
What case are you using? There is no such thing as a "Standard" case. They're all different.
Reply to sruane
Although not a cooling answer, I would reccomend that you buck up and get a 7200 RPM HD instead of a 5400.
Reply to akahuddy
Quote :
I know its an XION, but other than that I'm not sure about anything else-I've had it for about two years now and don't have the box anymore.
Reply to Izzardius
There are 536 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
