I recently bought a new xfx 7600 gt xxx from tigerdirect and for the first day it worked great, but later on i installed the latest ngo drivers and then i started to have big problems. I went into the nvidia control panel to check some settings and set them to my preference, but when i hit apply the computer froze and then the monitor shut off. When i restart, it would work fine untill i get to the desktop and about 2 seconds after it shows, the monitor shuts off again. I managed to get it working by reinstalling the nvidia drivers but i still cannot change any settings without this happening again. It is mostly only the overclocking settings too for some reason.
Afterwards i figured i would be fine for now as long as i dont touch anything. But when i went to do a benchmark in 3dmark 06 the monitor shut off again and the computer restarted. It was on the final graphics test right after a bunch of random jagged black lines popped up on the screen. And of course i just had to forget to turn off my computer at night and in the morning i woke up to my computer restarting by itself and showing fussy lines on the screen at the desktop. I think i managed to keep everything stable now except for the fact that the performance of the card has been cut in half. I used to be able to play cod2 at max with 35 fps now i get 15 tops.
Anyway i really dont want to go through the trouble of sending it back and wasting more money on shipping and everything. If anyone knows if this problem can be fixed or what the cause might have been then i would greatly appreciate your help
