Tom's Hardware > Forum > Wireless Networking > Setup, Configuration & Security > Help please..problem with Linksys WRT54G and WMP54G
Forum Wireless Networking : Setup, Configuration & Security - Help please..problem with Linksys WRT54G and WMP54G
Hi all,
Thanks in advanced for reading this...I have a Linksys WRT54G v.5 flashed to the latest firmware connected to a WMP54G v.4 WLAN PCI card running on the latest drivers downloaded from the net. I have another Centrino 802.11 b/g laptop as well. The problem I am facing is that I can connect the router and the card but the transfer rate is very very slow. Opening up google.com will take 2-3 minutes and logging on Messenger takes that long as well...I checked the connected speed>54Mbps...the transfer rate is 1Mbps though...i tried my centrino laptop, everything is oke...connected and transfer speed is up to notch...the next step, i reformatted my PC, but the same problem still occured...i used WZC to configure the card, still same problem...i scanned for WLAN network and found one running on a different channel...so I switched off my cordless phone and tried connecting whenever that particular network is not active, but still same problem...the weird thing is that i used it on my friend's machine on a different network and everything's fine...can anyone help troubleshoot what seems to be the problem here? i am beginning to suspect the WLAN card does not like my system :? Thanks!!
Sponsored Links
It sound like a MTU value is to high.
Go to DslReports under there tool section run Tweektest.
Reply to blue68f100
There are 611 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
