Tom's Hardware > Forum > Windows 2000/NT > Windows 2000/NT General Discussion > Wacky problem - need help - slow access speed
Forum Windows 2000/NT : Windows 2000/NT General Discussion - Wacky problem - need help - slow access speed
Archived from groups: microsoft.public.win2000.general (More info?)
I am using a Windows 2003 Enterprise server with Win XP Prof clients.
My problem has two parts to it - A) slow internal access to a RS/6000 using
a terminal emulator and B) slow when accessing the Internet using Internet
Explorer 5x and 6x.
This is what is happening. When the user logs on it takes a long time
before there is connection. after they logon the first time and logoff, the
next time they try to access the connection - it seems normal and faster?
However, this keeps changing back an forth,during the day.
This is happening both internally (via the LAN) and externally using a T1
line 512 bps.
I am using multiple switches, a Netopia Router and a T1 Router.
My Workstations have the internal DNS IP assigned to them.
My DNS server is forward to the Netopia Router
My T1 Router is pointing to the ISP DNS IPs.
Every thing works, but, slow as mentioned above.
Any help or suggestions appreciated.
Thx
Sponsored Links
Are you getting any errors in the event viewer on your DNS server? Do you
see all the clients registered in the DNS server?
"John Leonard - Sage" <sagegrp@adelphia.net> wrote in message
news:eMuqvN1cFHA.2644@TK2MSFTNGP09.phx.gbl...
using
> Explorer 5x and 6x.
the
> line 512 bps.
> Thx
Reply to David
No DNS error and yes clients are registered
"David" <david@david.com> wrote in message
news:edw8wM2cFHA.3156@tk2msftngp13.phx.gbl...
> using
>> Internet
>> Explorer 5x and 6x.
> the
>> line 512 bps.
>> Thx
Reply to Anonymous
- 0 +
What types of switches are you using? The switches could be having errors.
We have 3com managed switches here and I've noticed performance issues when
the switches were having a lot of errors. The errors were caused by smaller
hubs plugged into the 3com switches. They were having auto negotiation
issues. We had to force the 3com switch to be in a certain mode on the
ports that were plugged into the hubs. I would suggest looking into the
switch log if you have managed switches.
news:%23cilRO3cFHA.612@TK2MSFTNGP12.phx.gbl...
you
> > using
> >> Internet
> >> Explorer 5x and 6x.
> > the
faster?
T1
> >> line 512 bps.
> >> Thx
Reply to David
Using Dell switches.
I was having the same problem, when testing, before going live. I'll check
that out.
thanks
news:epBZAV3cFHA.2212@TK2MSFTNGP14.phx.gbl...
> errors.
> when
> smaller
> you
>> > using
>> >> Internet
>> >> Explorer 5x and 6x.
>> >> logoff,
>> > the
> faster?
> T1
>> >> line 512 bps.
>> >> Thx
Reply to Anonymous
There are 562 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
