mathias8888
6
Hi.! i have a problem with my ram.. im running 1 gig of corsair memory pc6400 in dual channel but in the bootscreen it says im runnig pc3200 rams in dual channel.
i dont know what is wrong.!
and b.t.w the mobo im using is a asus p5w dh deluxe with a e6600 core 2 duo cpu!
JimGoose
73
you could try going into your bios and into the memory settings section, then setting it to 6400 manually (which is DDR2 800 i think?). asus likes to set my ddr 400s as 333 when it's set to "auto" in the bios
mathias8888
6
oh.. i forgot to mension that either my bios doesent have a memory settings page or else im just blind... but i have been trough the whole bios a cuople of times and still i cant seem to find it.. any idea if my mobo might not have this page or where i can find it?
JimGoose
73
if it's an asus deluxe, no matter what model #, it should have a customizable bios O_O
it's tricky to find for the first time, and i can only speak for my asus mobo that uses a bios made by "award" but my memory settings for me are hidden inside "cpu configuration" then -> "dram settings"
i think.
mathias8888
6
i build it myself and bought the parts from different vendors... and i have overclocked the fsp 30% using asus ai overclock, so that might in some way interfeer with the rams?
JimGoose
73
:| don't use asus ai or any "auto overclock" features if you really want to overclock seriously. my experience is that they are ineffective compared to doing a little homework and o/cing manually through bios. just read up on how to overclock first, there are plenty of resources out there
p.s. a simple google image search of "asus p5w bios" turned up this pic
there's your section for DRAM frequency.
