System unstable please help!! Power??
Last response: in Components
I just built a new system which is unstable. It will randomly freeze, requiring a hard reboot. I suspect power supply. ABIT EQ reads low volts on 3.3 V power (2.88V), otherwise all normal temps, etc. I have an antec 500W PSU. Any suggestions?? New PSU, other?? THX.
AMD 5200+ x 2
ABIT K9 SLI board (nforce 570)
EVGA nvidia 8800GTS graphics
corsair 1 gb mem x 2
75 gb SATA HD
windows xp sp-2
all updated drivers.
More about : system unstable power
That's a hard one it could be alot of things.
could be badware?
you sure you have a good os install?
get a low end graphics card see if that helps. if its the psu you might use the adapter that comes with it to cross load your 12v rails.
see if your psu runs off 1 rail or are they joined for the 12v. That card is power hungry and your psu is really questionable as you suspected.
Quite possible that the PSU isn't giving you enough power. I assume the 75 GB drive you have is a Raptor.
Try taking out a stick of memory, disconnecting everything but your boot drive and your motherboard power plugs. Leaving your GPU connected, try booting and running some stress tests.
If you have an older video card, stick it in and see if it runs stable. 2.88v on the 3v rail is pretty low, but your PC won't draw much power from there.
Related ressources
I think the old psu was bad or at least on its way out with that low voltage reading. Either case, the Seasonic 700wt should be good enough for powering a new DX10 card. Good choice.
Ask the community
