Archived from groups: microsoft.public.win2000.general (
More info?)
I asked in the partner groups and a product support engineer agrees that's
the quick work-around. Quoted below.
I understand that some users have found after installing rollup for win2k
SP4, the system will either not come online or give errors of services not
being found, or the system has an additional symbolic link to the system
drive. The quick workaround is to use KB 223188, delete mountdevice key
from the registry.
We appreciate your valuable feedback on this issue and sharing the correct
resolution.
Currently, this issue is still under the investigation. This issue cannot
be reproduced in a normal W2k server with sp4, therefore, it is environment
specific issue and our develop team strives to found out the root cause.
I have tested install rollup for SP4 on the test machine, however, this
issue cannot be reproduced on my side. Personally, I suspect there is
certain application or service installed on the system to cause this issue
and I believe our develop team will get further on this issue in the near
future.
Again, thank you for your efforts on this issue and I also see your help on
other problems in the public newsgroup. I believe others will get benefit
from this!
Have a nice day!
Best regards,
Rebecca Chen
MCSE2000 MCDBA CCNA
Microsoft Online Partner Support
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
"Bob Erdmann" wrote:
|I have the same problem after the update
| My drive C is fine, but now I have a drive F
| that is a mirror of drive C
| which is killing my wins on startup
| also I looked at the other services
| and some of them are C:\winnt\system32\xxx.exe
| and some ar F:\winnt\system32\xxx.exe
| When i went into Drive Manager drive C:\
| had not been renamed to F:\. It is still correct
| I also noticed that in the Registry that only the files
| that are part of the windows update
| are listed in a path as f:\winnt\system32\xxx.exe
| F:\ drive would be the first open drive
| on this system, if i had added another drive
| Below is my registry entries for mounted devices
| it doesn't show a drive C
| so it isn't quite like the bulletin that you offered before
| so what is your feelings before i make any changes
| Bob
| Windows Registry Editor Version 5.00
| [HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices]
"\\??\\Volume{bf4093c2-06e8-11d9-9f3f-806d6172696f}"=hex:5c,00,3f,00,3f,00,5c,\
00,46,00,44,00,43,00,23,00,47,00,45,00,4e,00,45,00,52,00,49,00,43,00,5f,00,\
46,00,4c,00,4f,00,50,00,50,00,59,00,5f,00,44,00,52,00,49,00,56,00,45,00,23,\
00,35,00,26,00,32,00,63,00,64,00,38,00,36,00,33,00,30,00,36,00,26,00,30,00,\
26,00,30,00,23,00,7b,00,35,00,33,00,66,00,35,00,36,00,33,00,30,00,64,00,2d,\
00,62,00,36,00,62,00,66,00,2d,00,31,00,31,00,64,00,30,00,2d,00,39,00,34,00,\
66,00,32,00,2d,00,30,00,30,00,61,00,30,00,63,00,39,00,31,00,65,00,66,00,62,\
| 00,38,00,62,00,7d,00
"\\??\\Volume{bf4093c3-06e8-11d9-9f3f-806d6172696f}"=hex:5c,00,3f,00,3f,00,5c,\
00,49,00,44,00,45,00,23,00,43,00,64,00,52,00,6f,00,6d,00,48,00,4c,00,2d,00,\
44,00,54,00,2d,00,53,00,54,00,5f,00,52,00,57,00,23,00,44,00,56,00,44,00,5f,\
00,47,00,43,00,43,00,2d,00,34,00,34,00,38,00,30,00,42,00,5f,00,5f,00,5f,00,\
5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,31,\
00,2e,00,30,00,39,00,5f,00,5f,00,5f,00,5f,00,23,00,35,00,26,00,31,00,33,00,\
30,00,35,00,35,00,36,00,30,00,34,00,26,00,30,00,26,00,30,00,2e,00,30,00,2e,\
00,30,00,23,00,7b,00,35,00,33,00,66,00,35,00,36,00,33,00,30,00,64,00,2d,00,\
62,00,36,00,62,00,66,00,2d,00,31,00,31,00,64,00,30,00,2d,00,39,00,34,00,66,\
00,32,00,2d,00,30,00,30,00,61,00,30,00,63,00,39,00,31,00,65,00,66,00,62,00,\
| 38,00,62,00,7d,00
"\\DosDevices\\A:"=hex:5c,00,3f,00,3f,00,5c,00,46,00,44,00,43,00,23,00,47,00,\
45,00,4e,00,45,00,52,00,49,00,43,00,5f,00,46,00,4c,00,4f,00,50,00,50,00,59,\
00,5f,00,44,00,52,00,49,00,56,00,45,00,23,00,35,00,26,00,32,00,63,00,64,00,\
38,00,36,00,33,00,30,00,36,00,26,00,30,00,26,00,31,00,23,00,7b,00,35,00,33,\
00,66,00,35,00,36,00,33,00,30,00,64,00,2d,00,62,00,36,00,62,00,66,00,2d,00,\
31,00,31,00,64,00,30,00,2d,00,39,00,34,00,66,00,32,00,2d,00,30,00,30,00,61,\
| 00,30,00,63,00,39,00,31,00,65,00,66,00,62,00,38,00,62,00,7d,00
"\\DosDevices\\D:"=hex:5c,00,3f,00,3f,00,5c,00,53,00,54,00,4f,00,52,00,41,00,\
47,00,45,00,23,00,52,00,65,00,6d,00,6f,00,76,00,61,00,62,00,6c,00,65,00,4d,\
00,65,00,64,00,69,00,61,00,23,00,36,00,26,00,33,00,61,00,33,00,65,00,65,00,\
33,00,63,00,64,00,26,00,30,00,26,00,52,00,4d,00,23,00,7b,00,35,00,33,00,66,\
00,35,00,36,00,33,00,30,00,64,00,2d,00,62,00,36,00,62,00,66,00,2d,00,31,00,\
31,00,64,00,30,00,2d,00,39,00,34,00,66,00,32,00,2d,00,30,00,30,00,61,00,30,\
"\\??\\Volume{e1db6125-06ad-11d9-99e9-0007e92fce0f}"=hex:44,4d,49,4f,3a,49,44,\
| 3a,b2,62,29,cf,b2,25,01,42,b4,d7,c8,d7,9c,4a,83,c9
"\\DosDevices\\G:"=hex:44,4d,49,4f,3a,49,44,3a,b2,62,29,cf,b2,25,01,42,b4,d7,\
| c8,d7,9c,4a,83,c9
"#{e1db6127-06ad-11d9-99e9-0007e92fce0f}"=hex:89,a1,41,5c,00,7e,00,00,00,00,00,\
| 00
"\\??\\Volume{66190b1d-06b4-11d9-ace3-806d6172696f}"=hex:44,4d,49,4f,3a,49,44,\
| 3a,1c,0b,19,66,b4,06,d9,11,ac,e3,80,6d,61,72,69,6f
"\\??\\Volume{030a910a-06e8-11d9-961b-806d6172696f}"=hex:44,4d,49,4f,3a,49,44,\
"\\??\\Volume{53b9ef44-0809-11d9-8666-806d6172696f}"=hex:5c,00,3f,00,3f,00,5c,\
30,00,35,00,35,00,36,00,30,00,34,00,26,00,30,00,26,00,30,00,2e,00,31,00,2e,\
| 38,00,62,00,7d,00
"\\??\\Volume{797f5c6e-084f-11d9-99ec-0007e92fce0f}"=hex:5c,00,3f,00,3f,00,5c,\
00,53,00,54,00,4f,00,52,00,41,00,47,00,45,00,23,00,52,00,65,00,6d,00,6f,00,\
76,00,61,00,62,00,6c,00,65,00,4d,00,65,00,64,00,69,00,61,00,23,00,37,00,26,\
00,63,00,61,00,66,00,38,00,61,00,30,00,65,00,26,00,30,00,26,00,52,00,4d,00,\
23,00,7b,00,35,00,33,00,66,00,35,00,36,00,33,00,30,00,64,00,2d,00,62,00,36,\
00,62,00,66,00,2d,00,31,00,31,00,64,00,30,00,2d,00,39,00,34,00,66,00,32,00,\
2d,00,30,00,30,00,61,00,30,00,63,00,39,00,31,00,65,00,66,00,62,00,38,00,62,\
| 00,7d,00
"\\DosDevices\\E:"=hex:5c,00,3f,00,3f,00,5c,00,49,00,44,00,45,00,23,00,43,00,\
64,00,52,00,6f,00,6d,00,48,00,4c,00,2d,00,44,00,54,00,2d,00,53,00,54,00,5f,\
00,52,00,57,00,23,00,44,00,56,00,44,00,5f,00,47,00,43,00,43,00,2d,00,34,00,\
34,00,38,00,30,00,42,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,\
00,5f,00,5f,00,5f,00,5f,00,5f,00,5f,00,31,00,2e,00,30,00,39,00,5f,00,5f,00,\
5f,00,5f,00,23,00,35,00,26,00,34,00,62,00,61,00,35,00,35,00,66,00,26,00,30,\
00,26,00,30,00,2e,00,30,00,2e,00,30,00,23,00,7b,00,35,00,33,00,66,00,35,00,\
36,00,33,00,30,00,64,00,2d,00,62,00,36,00,62,00,66,00,2d,00,31,00,31,00,64,\
00,30,00,2d,00,39,00,34,00,66,00,32,00,2d,00,30,00,30,00,61,00,30,00,63,00,\
"\\??\\Volume{d16a0f56-1c8a-11d9-a4e5-806d6172696f}"=hex:5c,00,3f,00,3f,00,5c,\
76,00,61,00,62,00,6c,00,65,00,4d,00,65,00,64,00,69,00,61,00,23,00,36,00,26,\
00,33,00,61,00,33,00,65,00,65,00,33,00,63,00,64,00,26,00,30,00,26,00,52,00,\
4d,00,23,00,7b,00,35,00,33,00,66,00,35,00,36,00,33,00,30,00,64,00,2d,00,62,\
00,36,00,62,00,66,00,2d,00,31,00,31,00,64,00,30,00,2d,00,39,00,34,00,66,00,\
32,00,2d,00,30,00,30,00,61,00,30,00,63,00,39,00,31,00,65,00,66,00,62,00,38,\
| 00,62,00,7d,00
"\\??\\Volume{d16a0f57-1c8a-11d9-a4e5-0007e92fce0f}"=hex:5c,00,3f,00,3f,00,5c,\
26,00,31,00,23,00,7b,00,35,00,33,00,66,00,35,00,36,00,33,00,30,00,64,00,2d,\
"\\??\\Volume{76adc780-2179-11d9-b15d-806d6172696f}"=hex:5c,00,3f,00,3f,00,5c,\
00,2e,00,30,00,39,00,5f,00,5f,00,5f,00,5f,00,23,00,35,00,26,00,34,00,62,00,\
61,00,35,00,35,00,66,00,26,00,30,00,26,00,30,00,2e,00,30,00,2e,00,30,00,23,\
00,7b,00,35,00,33,00,66,00,35,00,36,00,33,00,30,00,64,00,2d,00,62,00,36,00,\
62,00,66,00,2d,00,31,00,31,00,64,00,30,00,2d,00,39,00,34,00,66,00,32,00,2d,\
00,30,00,30,00,61,00,30,00,63,00,39,00,31,00,65,00,66,00,62,00,38,00,62,00,\
| 7d,00
"\\??\\Volume{d9f3838a-8515-11d9-99ff-0007e92fce0e}"=hex:5c,00,3f,00,3f,00,5c,\
00,32,00,33,00,62,00,39,00,32,00,64,00,66,00,66,00,26,00,30,00,26,00,52,00,\
| 00,62,00,7d,00
"\\??\\Volume{d9f383ac-8515-11d9-99ff-0007e92fce0e}"=hex:5c,00,3f,00,3f,00,5c,\
00,34,00,36,00,61,00,31,00,34,00,37,00,62,00,26,00,30,00,26,00,52,00,4d,00,\
| 00,7d,00
@=hex:44,4d,49,4f,3a,49,44,3a,1c,0b,19,66,b4,06,d9,11,ac,e3,80,6d,61,72,69,6f
"\\DosDevices\\F:"=hex:44,4d,49,4f,3a,49,44,3a,1c,0b,19,66,b4,06,d9,11,ac,e3,\
| 80,6d,61,72,69,6f
