Ok, so i ordered a bunch of stuff from newegg including:
AMD Opteron 175
3 RAM heatsinks
Titan Water Cooling system
So, I put in the heatsinks and replaced the CPU, and tested it and everything ran just fine. I installed the water cooler then and everything was all fine. My Opty was running at 2.2Ghz at 26C. I decided it was overclocking time after running my system for about 1 1/2 hours to check for leaks/stability. I went to my BIOS and changed the FBS from 200 to 250 and started it up. It ran fine and it hit 2.8Ghz. I ran it liek that for about 10 minutes and it was only at 32C. So I went to overclock the FBS soem more. I ran it to 300 and started it up... except... it didnt start up. I tried starting it up again, but NOTHING. So, I figured maybe this opty couldnt run at 300 FBS, So, I cleared my CMOS and then started it up.. still absolutely nothing. I took the opty out and replaced it with my old Athlon 64 4000+. It didnt run still. I took that out and go out an old 939 motherboard I had and installed a RAM stick, the 4000+ and the vid card. and powered it up. It ran just fine. So i put teh opteron in that one and it didnt run... So I am stumped... I dont knwo what to do. I am guessing it somehow shorted out the CPU and the mobo. In which case I can just replace the mobo and exchange the CPU. But, I cant exactly do that because the water cooler runs through the PCI bracket and has water in it so I cant exactly disconnect it without water spilling.
Please help me, I am stumped...
AMD Opteron 175
3 RAM heatsinks
