I have a standard hp 3650 home printer connected to a computer on the network. I have tried nearly everything I know (yes it is shared on the network) and I can't get the other computers on the network to see it. By the way, I lost the installation cd. Any help and all suggestions would be greatly appreciated. Thanks
Sponsored Links
If it's a true network printer, just use add a new printer wizzard and select network, then use the http://ipaddress.
You can download the installer for HP's site.
Reply to blue68f100
Thank you I will try that.
Reply to krpoovey
Do you have printer and file sharing enabled? If you are running XP it helps to sometimes just run the wizard and walk through it so it sets the correct settings. You can do sharing manually and whatnot but there are sometimes hangups that sometimes get overlooked when setting it up. The wizard is actually a nice little gadgit and a time saver.
Reply to MikeyP410
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Printer sharing problem
There are 481 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 12:11 mi1ez won the Watchman badge
  • 01:00 sighQ2 won the Freshman badge
  • 09:06 ulysses35 won the CPUs badge
  • 01:00 fleeb won the Freshman badge
  • 01:00 jaymoney61 won the Freshman badge
  • 07:06 amdfangirl won the Watchman badge
  • 01:00 benw won the Freshman badge
  • 01:00 anmjoven won the Freshman badge
  • 01:00 dpnaugle won the Freshman badge
  • 01:00 ayeohx won the Freshman badge
