I'm wondering if someone could possibly post the settings that they used in order to get thier system past 3.2ghz and stable. I keep reading posts by people here who claim that they can overclock a 6600 to 3.6 or so, but from other sites I hear anything over 3.2 and you can't really use it to play on. Many posts say that 3.2 is about as high as they could go and be stable. I want to be able to play online games while overclocked, not just run benchmarks.
I have no problem with any heat issues from the what the monitors report, but when I go over about 3.25ghz my system won't boot to windows, or if it does, after about 5 minutes in, it totally freezes up. I've been able to get it to about 3.6ghz with core voltages around 1.5, but it just isn't stable. I've tweaked just about everything up and down from the stable point but can't figure out what I'm doing wrong. If it helps, I can get my bios settings later today when I'm at home, but I'm putting this in from work. Any tips would be appreciated.
I have the following, if that helps.
Asus P5WDH Deluxe motherboard
Intel 6600 chip (water cooled)
OCZ PC2-6400 gold memory
Maxtor SATA 300gb drive
750W Power supply
Tai-chi water-cooled tower
MSI Nvidia 7900 GS (water cooled)
--wondering also if running a single nvidia card on an ATI x-fire built board may be causing some issues? seems to run fine except when I try to push it higher.--
(edit note: I did start with the posted guidelines above and also have tried various other tips and suggestions from other boards to no avail, but I find that I like the posts I find here and feel comfortable asking you guys.)
750W Power supply
