Archived from groups: alt.tv.tech.hdtv (More info?)
I recently got HDTV receiver via my cable company -- Charter Communication.
So, here in upstate SC, I get a handful of channels, HBO, HBONet, Showtime,
ESPN, and a local channel. Not much. That comes in via the cable wire....
I'm wondering whether if I get an indoor antenna for OTA reception, and plug
that into the antenna in feed, will I be able to get some of the local
channels like fox, cbs, abc, WB, UPN in high def? If so, what antenna?
"Roger Zoul" <rogerzoul2@hotmail.com> wrote in message
news:107i7r6k7h4be14@corp.supernews.com...
Communication.
Showtime,
wire....
plug
I went to a OTA system Satellite and had good luck with most of the OTA
stations. I was having problems with 2 of the stations. They would not
always be available.
The connection for OTA and satellite came over the same cable by using a
transceiver to split the signal.
I changed satellite from DirecTV to Dish and went to a single feed for the
OTA [the old dual feed] and a new feed for Dish. I now have zero problems
with the OTA.
I would suggest that 2 separate feeds be used especially if you have 2 1080i
inputs.
"Phil Ross" <paross@pacbell.net> wrote in message
news:ckdec.20783$lS5.12026@newssvr27.news.prodigy.com...
> Try this site.
> http://www.antennaweb.org/aw/welcome.aspx >
> Communication.
> Showtime,
> wire....
> plug
On Sun, 11 Apr 2004 06:35:25 -0400, in article
<107i7r6k7h4be14@corp.supernews.com>, "Roger Zoul"
No, you won't. You'd need an OTA receiver for that. OTA uses a
different modulation scheme than cable does.
Stephen Tu
stephtu@surfbest.net
Communication.
Showtime,
wire....
plug
You have gotten some good info here on how to get local station info (via
titantv or antennaweb.ort). Where might you actually live? I might add
that avsforum has a number of threads for locals in SC that you might want
to peruse as well (specifically Western Carolina, Charlotte, Florence/MB,
Charleston, and Columbia). I personally visit and participate AVS as well
as this group; see
http://www.avsforum.com/avs-vb/for [...] forumid=45 for a list of
the local forums (page through or do a simple search). Good luck!
Stephen Tu wrote:
:: On Sun, 11 Apr 2004 06:35:25 -0400, in article
:: <107i7r6k7h4be14@corp.supernews.com>, "Roger Zoul"
:: <rogerzoul2@hotmail.com> wrote:
::: I recently got HDTV receiver via my cable company -- Charter
::: Communication.
::: So, here in upstate SC, I get a handful of channels, HBO, HBONet,
::: Showtime, ESPN, and a local channel. Not much. That comes in via
::: the cable wire....
::: I'm wondering whether if I get an indoor antenna for OTA reception,
::: and plug that into the antenna in feed, will I be able to get some
::: of the local channels like fox, cbs, abc, WB, UPN in high def? If
::: so, what antenna?
:: No, you won't. You'd need an OTA receiver for that. OTA uses a
:: different modulation scheme than cable does.
Bruce wrote:
:: "Roger Zoul" <rogerzoul2@hotmail.com> wrote in message
:: news:107i7r6k7h4be14@corp.supernews.com...
::: Communication.
:: You have gotten some good info here on how to get local station info
:: (via titantv or antennaweb.ort). Where might you actually live? I
:: might add that avsforum has a number of threads for locals in SC
:: that you might want to peruse as well (specifically Western
:: Carolina, Charlotte, Florence/MB, Charleston, and Columbia). I
:: personally visit and participate AVS as well as this group; see
:: http://www.avsforum.com/avs-vb/for [...] forumid=45 for a
:: list of the local forums (page through or do a simple search). Good
:: luck!
I'm in Greenville. I'll check out AVS...I'm a member there... Thanks.
