Hello...
So far this is what I have for my new build.
CPU = E6600
CPU cooling = Zalman 9500
Mobo = Gigabyte GA-965P-DS3
Video = EVGA 8800GTS
Memory = CORSAIR TWIN2X2048-6400C4
PS = PC Power & Cooling Silencer 610 EPS12V
I dont plan on OCing because I have never done it before. And with the money Im going to spend, hopefully i wont have to OC.
Im getting the zalman 9500 to make my system quiet.
Will the MOBO I have be good enough if i dont plan on OCing? Should I buy a better MOBO since im not going to OC.
Also, will 610W power supply be enough for the 8800GTS?
I have a 22 inch LCD monitor so i will be running games on 1600x1000 or whatever it was. With the games out now and the games that are planning to come out with DX10, do i need to go Sli? Or will just one 8800GTS be enough? If i need to, i would be willing to buy a 8800GTX also.
If i do buy a 8800GTX will the 610W be enough?
Thanks for the help!
CPU = E6600
