I got everything set up, I boot up my computer and I try to install windows but it says it doesnt detect my hard drive. I have the IDE cable connected and the power. Any suggestions on how to fix this? Also, is a floppy drive a required part?
only the HDD, the instructions and the bag of screws and a jumper came with it. Plus a cd.For a SATA drive you'll probably have to use a floppy (if one came with the HDD)
What do you mean by a 4 pin molex. Mine has a the big slot the jumper slot and then the power slot which has 4 male connectors in 1 row.
Jumper for a SATA HDD isn't for RAID... if it's a SATA II drive the jumper is to set it to SATA speeds on a mobo that doesn't support SATA II
The BIOS or CMOS or whatever doesnt detect it either.Well... installing XP on there... hmm... If XP won't recognize it then the only way I know of is to use a floppy. Unless the drivers are on that CD...
Try looking through that manual to find anything on that.
I'm not 100% sure but I think htat's only if you are going to RAID.
Yes I used the plug that goes into the SATA Driver and the Data and also the one that goes into the legacy power thing.
