Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > i need a new power supply, which 1 should i choose
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - i need a new power supply, which 1 should i choose
i just put another 8800gts card in for sli and my antec neo 550 isn't going to cut it. i am looking at the 2 psu's below and wanted some opinions and or reviews from you guys who may have expieriance with these.i would also be up for other recommendations as long as the price is in the same range and the psu has the modular cables.thanks
http://www.newegg.com/Product/Prod [...] 6817256009
http://www.newegg.com/Product/Prod [...] 6817153038
Sponsored Links
You picked great PSU's. They will do the job. You can even upgrade to one more 8800gts in SLI mode without a problem.
Reply to sarsoft
Quote :
A three-GPU SLI?
Reply to clue69less
Quote :
A three-GPU SLI?
My bet i just seen that he had a 8800gts already and he got one more 8800gts for an SLI. Thanks buddy.
Reply to sarsoft
thanks for the getting back guys, i went ahead and got the silverstone.i found it at a place i saw someone in the forums talk about. its called eastluna.com and it was 152 bucks shipped. hope they are as fast as the "egg"
also as a follow up last night i played half life 2 for like 2 hrs with everything cranked up and system runs fine,just didnt do much in 3 dmark06 compared to 1 card and when i try to oc cards it shuts down.could it be the second card is just bad?
Reply to big_tuna
can i put two 8800gts cards in an asus p5n-e sli motherborad?
Reply to cooler_power
Quote :
Sure as long as the case can accomidate the cards and the PSU has the power needed to power the system.
www.overclockers.co.uk says:
"These cards require PCI-E x16 slots, they will not function in a x8 slot so for SLi you need dual x16 mainboard. Finally 500W minimum for PSU and 600W+ is recommended."
Hi Big Tuna,
I recently purchased the 1K Silverstone. It's by far the best PSU I've owned. Very good quality.
Regards,
Howard
Reply to Howard_Stern
Quote :
Interesting. Considering that most SLI motherboard run the 2 16x slots in 8x when in SLI. Yet few people run into problem SLIing the 8800s.
I beleive what it's refuring to is somone wanting to SLI on a non SLI board by using the 8x slot not a 16x running at 8x.
A link directly to the article would help.
its not an article but a note in all the geforce 8 series cards they sell
There are 485 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
