HELP Moving Email & Settings to a New Machine!
Last response: in Windows 2000/NT
Archived from groups: microsoft.public.outlookexpress.general,microsoft.public.win2000.general (More info?)
Hi Folks -
I recently used the "files and settings transfer wizard" on my XP machine to
backup my outlook express email and settings so I can load it on a new Win2k
machine.
So I'm on the Win2k machine now, and have run the files and settings
transfer wizard again, this time directly from the WinXP cd, but for some
reason the "new computer" or restore options don't show up.
The only thing that shows up is the dialog that you normally get when you
back up settings!
All I want to do is load the email stuff I backed up earlier on my XP
machine onto this Win2k machine.
The two backup files I have now are:
1) IMG00001.DAT, and
2) STATUS
which reside in a folder called "USMT2.UNC"
I'm stuck. Any idea how to load this email stuff on my new machine?
Tom
See Tom Koch's web site for some excellent help on backup/restoring your
Outlook Express stuff.
http://www.insideoe.com/
Regards,
Dave Patrick ....Please no email replies - reply in newsgroup.
Microsoft Certified Professional
Microsoft MVP [Windows]
http://www.microsoft.com/protect
"Tom Newton" wrote:
| Hi Folks -
to
Win2k
| machine.
| back up settings!
| 2) STATUS
| Tom
FAST can be used to transfer *to* Win2K?? I don't think so.
References:
Backup & Restore OE Data
http://www.insideoe.com/backup/index.htm
http://www.oehelp.com/backup.aspx
OE Files & Settings
http://www.insideoe.com/files/index.htm
OE Registry Keys
http://www.insideoe.com/files/regkeys.htm
Importing OE Data (all DBX files, including Folders.dbx)
http://www.insideoe.com/faqs/how.htm#importOE5
Importing a single DBX file
http://www.insideoe.com/faqs/how.htm#importdbx
http://www.oehelp.com/backup.aspx (last paragraph)
~Robear Dyer (PA Bear)
MS MVP-Windows (IE/OE) & Security
Tom Newton wrote:
> Hi Folks -
> to backup my outlook express email and settings so I can load it on a new
> Win2k machine.
> back up settings!
> 2) STATUS
> Tom
Ask the community
