Change Power Off Settings in WM2003 SE via registry
Last response: in Cell Phones & Smartphones
Archived from groups: microsoft.public.pocketpc (More info?)
Best bet is to export registry, make changes, then export another copy
of registry and look for changes using a file compare on a pc.
Beverly Howard [MS MVP-Mobile Devices]
I tried that but the registry file was not viewable in notepad or word. I
used PHM Registry to export the registry from the Pocket PC. Can you
recommend any other programs that might export a file similar to a .reg file
on a PC?
"Beverly Howard [Ms-MVP/MobileDev]" <BevNoSpamBevHoward.com> wrote in
message news:uMEg%231UOFHA.1176@TK2MSFTNGP12.phx.gbl...
Did you try renaming the file extension? Try txt as it may be a text
file protected from easy/accidental/messing about type changes.
"Justin Kallas" <jrkallas@rockwellcollins.com> wrote in message
news:o ScbK5UOFHA.2928@TK2MSFTNGP10.phx.gbl...
word. I
..reg file
| on a PC?
copy
Related ressources
btw do this with a copy of the file, not the original. Just in case.
"alan smith" <alan@REMOVEmral.fsnet.co.uk> wrote in message
news:D 2s5m1$65t$1@newsg4.svr.pol.co.uk...
| word. I
you
| .reg file
| | on a PC?
in
| copy
No luck with that either. Any other ideas?
Justin
news:D 2s5oe$68b$1@newsg4.svr.pol.co.uk...
> | word. I
> you
> | .reg file
> | | on a PC?
> in
> | copy
All I can suggest is to try and use a registry editing tool that allows
selection/opening of a registry file then trying on a copy of your ppc
registry to see if it is properly viewed. Regedit in Windows98SE has an
import option. Look at whatever program is on your desktop to see if it
can import then see if it will understand your ppc registry- I'd guess
it will as they are both Windows but ..........
news:o %23O2mBVOFHA.508@TK2MSFTNGP12.phx.gbl...
| Justin
case.
text
or
| > | word. I
Can
| > you
to a
| > | .reg file
| > | | on a PC?
wrote
| > in
another
| > | copy
pc.
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Power\Timeouts]
"ACSuspendTimeout"=dword:00000000
"BattSuspendTimeout"=dword:0000012c
"BattStandByPeriod"=dword:00000004
"ACResumingSuspendTimeout"=dword:0000000f
"BattResumingSuspendTimeout"=dword:0000000f
"ACUserIdle"=dword:00000000
Frits JK
"Justin Kallas" <jrkallas@rockwellcollins.com> schreef in bericht
news:o kIzVuUOFHA.2680@TK2MSFTNGP09.phx.gbl...
>I am looking for information on the registry keys on WM2003 SE that control
> the power off settings for the device. I know this can be changed via the
> Settings, Advanced tab....however we are hoping to deploy a hard coded
> setting via the DMFP using SMS. Look forward to any replies on this one.
> Thanks!
> Justin
Thanks! That is what I was looking for.
Justin
"F. Janse Kok" <fjk@eb.nl> wrote in message
news:%23WRVZqVOFHA.2680@TK2MSFTNGP09.phx.gbl...
> Frits JK
control
the
one.
> > Thanks!
> > Justin
Ask the community
