Tom's Hardware > Forum > Home Theatre > HDTV > Need OTA HDTV Antenna Recommedations in Whittier, CA
Forum Home Theatre : HDTV - Need OTA HDTV Antenna Recommedations in Whittier, CA
Archived from groups: alt.tv.tech.hdtv (More info?)
Hi y'all.
I recently purchased an RCA DTC-100 receiver and will be using it to
receive DirectTV and OTA HDTV programming. I live in a two-story
house and have a direct line-of-sight to the transmitter towers on Mt.
Wilson less than 15 miles away. Over 90% of my OTA programming is
coming from Mt. Wilson including all of the HDTV. My sat dish is on
my roof about 25 feet up. My wife insists that I not put up a "big
ugly antenna" on my roof to receive OTA signals(please, no flames).
So I bought a Terk TV44 clip on antenna but I was very disappointed.
Hell, my rabbit ears inside my house had better reception!
What I would like is an antenna that is compact and that I could pipe
the signal through the same coax as my satellite with the use of
diplexers (like I was doing with the Terk) so that I wouldn't have to
run additional wires into the house(another wife requirement).
Thanx for any help.
Sponsored Links
You are right, the TV44 does not seem to work. If rabbit ears work why
not a better set with a pre-amp built in maybe you can even find one at
looks OK. Also are the OTA channels UHF, VHF or both. If UHF a small 4
bow-tie type antenna should work well. (I don't, however, know much
about sending the antenna signal down a Dish cable.)
Good luck.
El Mojado wrote:
> Hi y'all.
> Thanx for any help.
Reply to Anonymous
Duplex is industry standard. As I said in an earlier post I had reception
problems develop over time that was finally found to be duplexer in the
cable. I ran a separate OTA cable and the problem disappeared.
"El Mojado" <mojado44@yahoo.com> wrote in message
news:56757fb7.0404141256.70d009ce@posting.google.com...
> Hi y'all.
> Thanx for any help.
Reply to Anonymous
- 0 +
mojado44@yahoo.com (El Mojado) wrote in
> Hi y'all.
Try a zenith silver sensor (sold at Sears and elsewhere). I'm around 40
miles away from Mt Wilson and get the major channels in L.A.
Reply to darius
I have an indoor OTA amplified antenna that works great when you have good
line of sight. Flat, indiscreet, easy to use. Even has an extra input. Got
it at Best Buy, think it is a Jensen.
in article 5948648043.8554256396.38092@news.verizon.net, darius at
noone@here.invalid wrote on 4/15/04 4:15 PM:
>> Hi y'all.
Reply to Anonymous
- 0 +
I live 45 miles from my towers. I have the same experiencs with a
terk 55, i.e. terrible. Old rabbit ears worked better. What a scam.
I got a 15-880 amplified indoor antenna from radio shack for $50. It
gets pretty much all the stations but I have to move it a few degrees
between stations to point right at the towers. Since you are closer
it will probably pick your stations up no problem. I'd give it a try,
you can always return it.
I am currently installing a channel master 4228 outside so I can get
all stations without having to mess with anything, and maybe getting
some more stations. But it's about 4'X4' so it's pretty ugly.
Reply to steve
- 0 +
All the digital tv broadcasts off Mt. Wilson are UHF. I'm in Redondo Beach,
about 30 miles from Mt. Wilson. I recently installed a Channel Master
3021/4221 UHF only antenna. It passed the ugly test with my wife and
neighbors. For a picture see this URL:
http://www.channelmaster.com/images/3021_4221.jpg
I pull in all the digital stations that are broadcast from Mt. Wilson
(nearly 20 channels with some HD programming on at least seven or eight).
It's installed on a 10' mast with no amplifier and about a 50' cable run to
my receiver. I pointed it by eye (for me, about 30 degrees east of north). I
simply took an auto club map and drew a line from my location to Mt. Wilson
and measured the angle. You could also go to www.antennaweb.org , but they
give a bearing relative to magnetic north.
I ordered the antenna at my local Ace Hardware store on a Monday and picked
it up the following Thursday. I paid $27 plus tax (no shipping).
Alternatively you can order it from the Ace site and have it shipped for
free to the store...but in that case the local store doesn't get any profit.
Here's a link to a page at the Ace hardware site
http://www.acehardware.com/entry.j [...] ry=1291860
good luck
--jay
> Hi y'all.
> Thanx for any help.
Reply to jay
A Radio Shack 15-1880 works pretty well if put at an upstairs window
facing in the general direction of the tower. However, BE SURE to rotate
the UHF loop so that it looks like a figure-8. It comes out of the box lying
on its side like the symbol for infinity, and gives poor reception that way.
I am in the South San Francisco Bay area, and can get all the SF digital
stations about 30 miles away, and even a Novato station about 45 miles
away with a single antenna location. ( I can also get some relatively close
stations even though they are in an entirely different direction.)
I would like to get KRCB-DT, which is about 70 miles away. This does not
come in routinely. However, using a Zenith Silver Sensor directly attached
to a ChannelMaster 7775 preamp, I have been able to lock in KRCB-DT
most of the time when the weather is hot and dry (but not at all when
the weather is cold or wet).
Surprisingly, I can pick up an analog station that is 90 miles away fairly
well. The reception is stable, although there is snow, if I put the antenna
in a "hot spot" for that channel. The line of sight to this (and also to KRCB)
is mostly over the water of SF Bay.
Paul
Email: lastname at best dot com. No spam please.
All spam will be complained to sender's ISP.
Reply to Anonymous
There are 759 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
