Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > ice/water cooling system
Forum Overclocking : Cooler and Heatsinks - ice/water cooling system
mmk....
the idea for my watercooling system
step 1.get a couple 2 liter soda bottles
step 2.put 2 holes on either end of them
step 3. put like a sleeve over the stick
step 4.put a stickk in the two holes
step 5. put some water in
step 6. freeze the water in the bottle over the stick and its sleeve
step 7. take the stick out w/ sleeve still in since its stuck to the ice
step 8. put the tube to my computer that is outside my computer in the two holes.
step 9. hook the tube back to the radiator.
step 10. there you got an easy water/ice cooling system eh??
or will that not work??? think iam crazy lol??
resivior>>pump>>all my parts>>radiators>>through the bottles>>back to the resivior>>etc
would that work?? or not worth it??
Sponsored Links
lol, and i thought i was suprised when i first saw toilet watercooler
Reply to Assman
but wouldnt the water be hot enough when it goes to the bottles that it will be hot enough to melt the ice and not instantly freeze?
iam confused with my own mind lol
Reply to lewbaseball07
so water would form outside of the tubes inside the case?
and that is why i have a c in science and no other class lol
how could i "Safe guard" it from condensation?
i think a dehumidifier would take away most of the moisture.
could i rap the hoses in something.....
Quote :
LOL, or the Afrotech's water cooling method.
http://www.afrotechmods.com/stupid/water/water.htm
Reply to chuckshissle
I'm curious as to how you expect the ice not to thaw and leak out the gaps around your tubing or just thaw period and have to take great pains to refreeze it?
Or are you planning to keep the bottles in a freezer somehow and run the tubing through holes in the walls of the freezer to keep that chilly temp. Also what Mpilchfamily said about condensation. Ice cold and you'll run into probs with that.
To Assman: OMFG man!! It took me what felt like 10 minutes to see your tags cycle all the way through. How many is that? On the other hand some T&A while forum browsing is right up my alley as well so woot!
Reply to Talon
Quote :
lol, the're 85 pics, i didn't use ubanimator.com this time cause they limit num. of pics to 10.
@ Chuckshissle: lol, "Captain Afro's Ghetto Water-cooler" some people just have too much free time on their hands :)
Reply to Assman
Quote :
OK lets just say you do get it to work without leaks. You run into a problem here. You will have to safe guard the system from condesation. The water will be ice cold so you will get condensation buildup on the tubing inside the system. There is just to big of a risk for water damage in the system.
I'm no expert in physics... don't know your flow how cold the ice is going to be...
but i was thinking that it may be possible that the water won't go don't below room temperature... but the heat removed from the CPU could be equal to the amount of heat absorbed by the ice.
but i just think that it will work for 5 min then after the ice has melted you system will overheat.
just my 2ยข
Reply to MadHacker
Thanks for the Toilet Cooler Link!!
That was great and pretty funny too....
Hey I know, I'll combine my two favorite things (plumbing and computers) :)
Gotta love it....
Lets see where does that put me (woodworking and computers) I know something good could come of that :).
Reply to Ches111
Woot to wood and computers.
Reply to tool_462
You would have to coat your CPU connections with dielectric grease, put a neoprene foam pad around your waterblocks, and use a surficant (like a very thin layer of silicone) to waterproof your mainboard. You can also surround your tubing with neoprene foam so it does not come into direct contact with the air in your computer, but you would still have to take waterproofing precautions with your waterblock.
The trashcan/radiator idea would work, and you can keep adding ice to the trashcan to keep the water cool when the ice starts to melt.
The two liter bottle would work, but not efficiently, since you want the water to dump as much heat as possible into the ice, and a single pass round tube would not do a very good job. Now, if you were to freeze a radiator inside the bottle and then pass cooling fluid through it (you would have to use antifreeze, or the fluid would gel up and your pump would not be able to move it), I could see this as being efficient, at least until the ice melts.
Reply to Houndsteeth
There are 965 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
