Hello,
I have a sound blaster sound card but it's msotly only allowed on 32 bit systems i cant seem to make it compatible with my 64 bit wondows seven OS can anyone tell me if theres a way to do this?
What do you mean "mostly" allowed? It either runs on 64 bit Windows 7 or not. If there are no official drivers, you can try 3rd party drivers like http://kxproject.lugosoft.com/
SB has pretty much always have had crappy 64 bit support.
Its not the hardware so much as the drivers that need to be 64 bit. The driver is what makes communication between the OS and the hardware possible. If Creative doesn't have 64 bit drivers for this card on their site, it's not going to work.
