case: http://www.newegg.com/Product/Product.asp?Item=N82E16811233006
proc: E6400 2.13 core 2 duo
power:http://www.newegg.com/Product/Product.asp?Item=N82E16817190007
cd:http://www.newegg.com/Product/Product.asp?Item=N82E16827106048
vid:http://www.newegg.com/Product/Product.asp?Item=N82E16814130056
ram: http://www.newegg.com/Product/Product.asp?Item=N82E16820145590
my old mobo booted up fine the first two times, the second time i went into the bios and the cd drive was labeled as slave, not master, so i turned it off and it wouldnt display on the monitor anymore, mobo said a vga error, but whenever the ide cable was plugged in, it shorted the cd drive, which no longer got power unless the ide cable was unplugged. Gonna test my vid card later today, but im pretty sure i need a new mobo.
http://www.newegg.com/Product/Product.asp?Item=N82E16813138037
Im thinking of getting a different mobo that will not fail me, maybe a little more expensive than that one. ANY suggestions?
