This one is doing my head in
ASRock 775DUAL-VSTA Motherboard
Bios 1.90
Intel Core 2 Duo 6300 Processor
2 X Adata DDRII 667MHz RAM
Samsung 80Gb S-ATA Hard Drive (set to 150Mb)
ASUS PCI-Ex Radeon X550 Graphics
etc
I had an order for 25 of these. First system built fine, Windows XP Home installed, all drivers, etc. Cloned the hard drives, installed into the other PCs and tested, baring a few glitches all pretty much fine. However the PCs are going to a school with a schools agreement, so they are upgrading to XP Pro.
School called yesterday to say that XP Pro would not install on the first 2 PCs tested. I still have some here so tried installing onto one and it failed. Error copying windows file, a common indicator of a memory problem.
Trawling the web identified various suggestions to do with memory settings, and even the ASRock web site suggests problems with DDR II memory for bios pre 1.80. Have tried a combination of settings but without complete success, can get further into the install but always fails at some point.
Switching to 2 X Adata DDR400 512Mb memory sticks on the same PC and the install works fine, so clearly a DDRII 667 issue.
Am trying on another PC with DDRII installed shortly, if anyone has any suggestions as to the correct memory settings then please post.
ASRock suggested changing the install CD or the cable, not particularly helpful as I already identified the problem is related to DDRII.
Bios 1.90
etc
