I'm connecting up the front panel on my Jeantech Nitro.
To my Gigbyte GA-965P-DS3
In the Giga manual it states that the polarities must be correct for the front panel connections or it will cause damage.
Unfortunately some of the connections are not labelled for polarity.
They are just colour coded orange and white etc.
Do I take it that the white cable is the negative as there is no information with the Case or on the Case website.
Also the USB front panel connectors the motherboard has two rows for each connector they are:
Power, USB DX-, USB DX+, GND
or
Power, USB Dy-, USB Dy+, GND
yet on the front panel cable its labelled : Power, USB D-, USB D+, GND
So which row do I use?
Sorry for the stupid questions this is my 2nd build and my last build was 7 years ago.
or
