Hi,.
just build a system which contains,
Biostar Tforce4u-775
WD 3200KS
Intel D 925
Corsair CM2X1024-6400
eVGA 6200LE (will be replaced)
my problem is, that i could not install Windows Xp since the system freezes all time. I checked all jumpers and connections, but everything seems to be fine.
At boot the system shows the ram (ok), cpu (ok) HD (ok) and my cd rom (ok)...
but then it goes to shit.
I thought first, it may be the memory since it is a 800mhz module, but that should not be a problem i think.
Is my motherboard DOA?
WD 3200KS
Intel D 925
