I'm building my first computer and i need some help!
  • Homebuilt
  • Motherboards
  • Memory
  • Systems
  • Product
Last response: in Systems
January 11, 2007 8:43:16 AM
Hey yall
Well pritty much i just need to know weither the motherboard, CPU and Memory will work together.
Motherboard:
ASUS P5B-V CORE2DUO, G965, 2xPCIE, VGA, DDR2, SATA2, SND $242
CPU:
INTEL CORE 2 DUO E6600/ 2.40GHz/ 4MB CACHE/ 1066FSB/ LGA775 $499
Memory:
GEIL PC2-6400 800MHz DDR2 Ultra Dual Channel 2x 512Mb Heat Spreader Hand Picked $229
By the way there Australian prices!!
Thanks
Genusis
More about : building computer
January 11, 2007 9:17:31 AM
Hi,
My advice is to look at the mother board for information. If you have decided on the cpu you want make sure the motherboard has the right cpu socket for it.
So look at the motherboard stats from their website, that will tell you what brand and sockets it supports.
Again with the ram it will tell you what type of ram, what speed and how much you can put in it.
Hope this helps you.
Colin.
January 11, 2007 9:38:36 AM
K well just letting you know if your reading this post i'm not stupid
i have made sure its right i just need some reassurance before i buy it.
oh and no affence colin
January 11, 2007 9:48:00 AM
Lol yeah they do all work together.
The motherboard is a G965 though which means it has integrated Graphics onboard. Try the Asus P5B, Gigabyte P965 DS3 and the Abit AB9 PRO if you want some other boards.
January 11, 2007 11:16:30 AM
thanks
