Tom's Hardware > Forum > General Networking > Network General Discussions > Help--can connect through cable modem but not through router
Forum General Networking : Network General Discussions - Help--can connect through cable modem but not through router
OK, I need massive help.
I have two computers. I have a cable connection to the internet. Both computers work great on their own connecting directly to the net via the cable modem.
However, once I try and put a router in between them so both computers can use the net at the same time, while one still works, another just simply cannot connect to the internet.
On the problematic computer, I've tried changing out network cards (I bought a new Linksys network card to try and match the Linksys router I was using on the theory that there might have previously been compatabaility issues), I've made sure TCP/IP is installed, I've compared the network card's setting to those of the computer that works and they seem equivalent, I've tried two different routers.
I need help mates. Why won't a computer that can connect directly to the net via a cable modem not connect through a router, while what is a seemingly identical computer configuration on another computer works fine either way?
Please help. Thanks
Sponsored Links
Make sure your router is set up in NAT mode... most ISPs only give you one public IP. configure your router to grab the public IP. Configure your router to be a DHCP server and use it to assign private IP addresses to your computer. If you have one of the consumer routers, i.e. from linksys, netgear, dlink, etc... you should just be able to plug it in and go.
Reply to El0him
There are 1288 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
