Hi I'm about to buy a new computer but before I pay for anything I'd like to know that everything I'm going to buy are sensible choices and what speed I could overclock to. The components are:
CPU: E6300
Motherboard: Asus P5B Deluxe
Memory: Corsair XMS TWIN2X2048-6400C4 (2x1024MB DDR2-800 4-4-4-12)
Hard Drive 1: Seagate 320GB 7200.10
Hard Drive 2: Seagate 300GB 7200.7 (I already have it)
Graphics Card: ATI X1950 Pro
Optical Drive: Gigabyte GO-W1616B - link
Power Supply: ThermalTake 700W ToughPower - link
Case: Gigabyte Poseidon - link
Monitor: ViewSonic VX922 (I already have it)
Speakers: Logitech Z-5500 (I already have them)
I'd like to be able to easily get to 2.8 GHz (400MHz FSB). Is this possible with stock cooling and this setup? Or would getting an E6400 be more of a guarantee of getting 2.8 GHz. Is the RAM good enough/overkill, could I get away with 5-5-5-12 timings (still DDR2-800)? If I go with the 5-5-5-12 RAM and an E6400 I'd save $30. Would this be a good idea or should I go for 4-4-4-12 and the E6400 and pay the extra $40 it'd cost me?
Also I'd like to upgrade the GFX card in the future to something like a 8800 GTX. Would this be possible in this setup (i.e. would it fit)? And if you think I am wasting money anywhere please tell me because I am on quite a tight budget (this is about the max I am willing to pay, its 2325 New Zealand dollars for what I have left to buy).
Oh yeah and the only thing which I'm likely to use the computer for which will actually need all of the processing power is games.
Thanks
CPU: E6300
Thanks
