Tom's Hardware > Forum > Overclocking > Motherboards > System power flashes on and off.
Forum Overclocking : Motherboards - System power flashes on and off.
Hey all, thanks for reading.
Basically, my problem is as follows. My motherboard turns on for ~ 1/10 of a second, and then powers down. I dont know what could cause this. Any ideas? The problem started when I was doing some maitenence on my watercooling, and I am pretty sure that some of the water landed on the motherboard itself.
I'm pretty sure it is a short somewhere, if there is something specific that causes this type of behaviour, I would like to know.
Thanks
-Joe[/i]
Sponsored Links
Generally when I've seen that, it's been either a bad power supply, or the CPU fan wasn't seated or connected properly.
-J
Reply to cmptrdude79
Well. I dont know if it is the PSU or not. I did ye old Green + black wire trick, and the rest of the system powers on fine. I dont know about the CPU fan though, Ive got a waterblock on it, and thus, there is no fan, though I did try powering it on with a normal 3pin fan connector attached to it.
Reply to -Faluzure-
Ok, just discovered more, I can turn on the PC if i dont connect the 4 pin connector.
Reply to -Faluzure-
If it's a core 2 system, it will be memory compatibility. Try changing to a different type of memory and ensure it is compatible with the board.
I had that exact same problem with mine, except that it would cycle on and off constantly.
Reply to Dave262
Yeah, its not a core duo board, its definatly a P4 i865 based motherboard(478).
Reply to -Faluzure-
The best way to verify your problem is try another good PSU with the bare minimum of devices plugged in, aka the CPU one stick of RAM and nothing else. If it does not have onboard video, the system should be able to boot up long enough to give a POST error.
If the same thing happens, check to make sure nothing is shorting out the mobo, make sure the HSF is seated properly, that there is no concentrated amounts of dust on the mobo, and nothing with any burn marks.
Also, check the tops of the capacitors (they look like pop cans) - if any are swollen, i.e. not flat on top, then the board is done.
Reply to blueeyesm
Checked all that stuff, no dice.
I ran the machine out of the case with only the PSU (tried 2 different ones), a CPU and ram. I also tried it without ram (the system shoud give me a nice long beep), but still will not power on.
Reply to -Faluzure-
Alright, I dont need any more help. The motherboard is dead, it exploded.
Reply to -Faluzure-
There are 822 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
