What do you call the can of spray that you use to remove the thermal grease on a CPU? I'm trying to find the stuff on newegg but no luck so far. Thanks.
CRC QD Electronic Cleaner
You can find it at any Auto Parts Store, CRC makes different cleaners just because the can says CRC you need to make sure its the electronics cleaner, its designed not to hurt substrates, and plastics, dries almost instantly, cleans whatever like brand new, CPUs, GPUs, heatsinks, Etc. I always keep a can on hand and use it all the time its a real time saver.
