Every time XP MCE boots up on my PC (either from cold or from a restart), I have no sound, and in Control Panel > Sounds and Audio Devices it says "No Audio Device".
If I then go into Device Manager (which has no conflicts/problems showing) and right-click Sigma Tel High Definition Audio CODEC and choose Uninstall, then after that choose Scan For Hardware Changes, Windows re-adds it and sound works fine again.
Until I restart, or turn off, then next time I get the same error. Logging off back to the XP logon screen doesn't cause it to lose the audio device, just restarting or turning on from cold.
I have a Dell DXP061 motherboard with Dell/Phoenix BIOS rev 2.0.5
Intel Core 2 Duo E6600 @ 2.4Ghz
2GB Samsung DDR2 SDRAM @ 667Mhz
nVidia GeForce 7950GX2
The driver version for Sigma Tel HD Audio CODEC says 5.10.0.4991
