I gota E6400 running at 3ghz and a freezer 7 pro on it.
When the cooler is set to "Max" the idle temp is around 33C/90F and the fan spins at 2500rpm.
When i put it on "Auto" in the bios the idle temp is around 45C and the fan spins at 1000.
Is there a way i can set the fan to spin at some middleground to get a lower temp then 45C but without the noice?
Some of the bios options (Legacy?) sais it changes teh fanspeed according to the temp. But how does it deside what the best fanspeed is?
Is there a way I can ajust the "Auto" settings so that it keeps the cpu cooler then the 45C it's on now, or is 45C "the normal"?
I dont know if it mathers, but without OC the temp was around 22C on max and 35ish on Auto.
