Archived from groups: alt.tv.tech.hdtv (More info?)
I have a Yamaha 5.1 and two tower speakers, center one (two 5 inch and
tiny tweeter), and two RCA in the rear.
Problem: The Center speaker is hard to understand the people talking, and I
turn it up. Then there is a explosion, gun fire or music, and the twower
speakers kich in with the 15 inch Woofers and you come right out the chair.
I've got to change something, but don't know which way to go.
"Joe H" <JoeT@mailpuppy.com> wrote in message
news:UsidnQW_jbhv7wzdRVn-uw@giganews.com...
and
I
chair.
My Pioneer has individual level adjustments for each speaker. Yamaha must
have something similar.
Are you listening to dolby digital material or Pro Logic?
If you calibrated your speakers (with test tones from AVIA DVD or other)
than your problem may be solved by sound compression if you are listening to
Dolby Digital. The Yamaha amplifier allows for this in the settings ; go to
"Dolby RNG" and select LOW out of Wide, Standard and Low.
Otherwise, if you are listening to Pro Logic you may boost your center
speaker a few decibels relative to the main one. In extreme cases, you
should have a main speaker attenuation switch at the rear of the amplifier
to usually allows you to decrease to main speaker output by 10 decibels.
Good luck!
and
I
chair.
> inch and tiny tweeter), and two RCA in the rear.
> and I turn it up. Then there is a explosion, gun fire or music, and
> the twower speakers kich in with the 15 inch Woofers and you come
> right out the chair. I've got to change something, but don't know
> which way to go.
I agree with recommendation that you must calibrate. $25 for the DVD and
another $25 for the SPL meter from Radio Shack. Best investment for AV
use.
Yes, so does mine and I have adjusted them several times.
I believe the problem is my tower spearkers are set up too good with my
electronic cross overs from radio shack.
I took the yamaha center speaker apart today, and it's a bad news cross over
and the voice rance just isn't there. It has two 5 inch in it, but that
upper range one is out for now and I'll be picking up a speaker to replace
it.
"bearman" <noyb@home.com> wrote in message
news:IsidnQEoBKiX6gzdRVn-vg@comcast.com...
> and
and
> I
> chair.
> Bearman
Check the settings on your decoder, there is a setting that reduces the
level of the center channel
> and
> I
> chair.
> Bearman
