Tom's Hardware > Forum > Graphic & Displays > ATI > Major X1650 problems
Hi there,
I recently purchased a HIS Radeon X1650 Pro Ice-Q 512MB AGP video card. I installed it correctly, making sure I powered it up using the floppy power cable. But when I boot up my PC the screen remains black, normaly it "jumps" on, the orange LED usualy becomes yellow, but it doesn't. The monitor just doens't get a signal. The fan on the videocard is running fine though. Although I can hear the harddrive spinning when windows is booting, the screen remains black. When I installed the videocard in another system it worked perfectly fine. I've tryed everything, for example I disconnected very piece of hardware leaving only the videocard, but it still doesnt work. There is a new BIOS update available for my motherboard, but it's a beta version, so I'm a bit anxious installing it. I also tryed using another monitor. Here are the specifications of my system:
ASUS K8V Deluxe Motherboard with BIOS v 1011
AMD Athlon64 3200+
2*512MB Kingston ValueRam
Tagan 480W Power Supply
And the specifications of the other system:
(works fine on this one)
MSI K3T Motherboard
AMD Athlon 1,15 Ghz
2*512 RAM
Unknown Power Supply
By the way, I've done some research on the internet and I found some other people with the same problem:
http://forums.filefront.com/showthread.php?p=3465226
http://www.driverheaven.net/showthread.php?t=126330
Haven't found a solution thouh.
BTW, excuse me for my bad english as it is not my motherlanguage :)
I realy hope somebody got a solution to this problem, whould realy appreciate it.
Sponsored Links
It has nothing to do with the BIOS...but I'm not sure what the problem is. Have you tried using both outputs from the video card?
Reply to miahallen
Quote :
Thanks for replying,
Yes I've tried both. VGA and VGA with DVI -> VGA adapter. Doesn't make a difference.
Reply to o_Omgwtf
Have you tried putting another card BACK IN (since the problem arose) to see if the slot's still good?
Reply to miahallen
Quote :
Yep, my old videocard works fine, nothing wrong with the AGP slot.
Reply to o_Omgwtf
There are 1550 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Latest best answer
Graphics cards
By frozenlead, 7 hours ago:
Ahha. You mean this: http://www.tomshardware.com/review [...] 521-8.html
Top experts
