Hi this is my first post and I have this big problem....
I had 56k on my home but then my neighbor told me that if I bought a wireless router He would let me get internet from his house whose is 1 mbps so I bought 2 Linksys WRT54gx2 routers with srx 200 and mimo technology .. the thing is that I connected one to the modem and every led is ok (Power, internet. wireless) and he has conecction on he's laptop but then I put near outside the other router to extend the conecction range, I just plugged turned it on and the power led is on and Wan but the internet led is off and in my house I have signal ( very low) but still I can connect but I cant search or do anything on the internet , its as if I dont have any connection, and I have 17% fo signal from this router and my neighbor nex to me has a belkin pre n wireless router and I get -4% of signal but with that I can search all over the internet and download!
So can you help me , do I have to insert my router Disc ( the problem is that I need to be online with the router and the router is n my neighbor house and my pc is a desktop)
Well what you did wrong was buy hardware without knowing the capabilities. Perhaps your router is different than just about any other out there and it does have a repeater mode. Or WDS bridging client. It would be very unusual.
So what makes you think this would work in the first place? In other words, how did you come to the conclusion buying two wireless routers would allow you to repeat the signal to your house?
